i decided to replace my hobbycnc controller with a G540 (no issues with the hobbycnc board, just wanted to try something different) and i got everything wired up and have a green light and have holding torque on my motor, but when i jog in Mach3, i get no movement. I haven't installed the G540 XML, but i changed the pins in the ports and pins section manually (i changed step and direction pin from 2 and 3 to 3 and 2 or vice versa and changed to active high, but other than that, the pin setup is similar between the hobbycnc and G540 boards). i was trying to not install the XML file because i didn't want to loose all my settings for my hobbyCNC board, which can still be hooked up.
any ideas or things to check for why i have holding torque but no movement?
