586,055 active members*
4,340 visitors online*
IndustryArena Forum > CNC Electronics > Gecko Drives > G540 switched mode power supply
Results 1 to 3 of 3
    Jan 2010
    76
    i bought a 48V power supply off amazon (48V, 350W, 8A) to run my G540 with 3 stepper motors. i read some information from Gecko that they like unregulated power supplies because they absorb voltage sent back from the motors during rapid deceleration. do i need to worry about this with my switch mode power supply? if i put a large capacitor in parallel with it, would that help? I also read where Gecko had tested some cheaper power supplies and they were causing the G540 to pop because they would go to to high a voltage. is there anything i can proactively do to make sure that doesn't happen?
    1943
    Re: G540 switched mode power supply
    Just hook them up. The switching power supply will work fine.
    Mar 2007
    2083
    Not all switch mode power supplies are the equal
    Success or failure will depend on what brand of power supply you have
    if its a genuine Meanwell power supply for instance , I expect it will work
    a cheap copy is more likely to output bursts of voltage over the intended 48V
    and cause the G540 to malfunction and possibly damage one or more of the G250 stepperdrivers
    ( if I remember correctly a resistor and 70V zenner diode is connected across the supply to give visual indication the driver has been subjected to more than 70V !!!! )
    John
  1. switched to demo mode
    By pchfurniture in forum BobCad-Cam
    Last Post: 05-02-2016, 10:11 PM
  2. Replies: 2
    Last Post: 08-21-2014, 10:22 PM
  3. Replies: 8
    Last Post: 11-30-2012, 10:15 PM
  4. 4 quadrant drives and switched mode power supplies
    By daedalus in forum Servo Motors / Drives
    Last Post: 12-15-2006, 06:25 PM
  5. Switch Mode Rectifier as power supply
    By andy_ck87028 in forum Stepper Motors / Drives
    Last Post: 04-30-2006, 04:17 AM
