587,013 active members*
3,803 visitors online*
    Looking for Cnc plasma table
    First post, I am a artist/sculptor looking to buy a 4x4 starter plasma Cnc machine for my business. Question is, if I build my own water table is it possible to get a decent Cnc setup for $4,000.00 dollars.? Can someone suggest or steer me in the right direction. I usually use 090 or 1/8 aluminum on almost everything. I have a power max 380 hyperthermia plasma and a big air compressor and computer, thanx in advance Tony Viscardi
    website Contemporary art & Sculptures
    AllenOmnicnc Guest
    Re: Looking for Cnc plasma table
    Another arcing position Omni 1530 Hyperthem 105A power cutting 5mm steel hole
    https://youtu.be/qAmNO3-Hbok
    AllenOmnicnc Guest
    Omni also sell cnc plasma cutter without power, 1200*1200mm+3 axis Hiwin rail +Start brand THC+6mm thickness blade table+stepper motor +Start control system.
    Apr 2003
    540
    If you talking about with a controller, motors and electronics included, you're right at about the very, very bottom prices I've seen for a 4x4 plasma. Most start around 4500. You can prob communicate with a few of the sellers on the web or ebay and buy just the table and then buy/install your own electronics (and THC if you want one) and save a little bit. You'll also learn more and be better equipped to troubleshoot issues if you do it yourself. Of course then there's software if you don't already have Mach3, Sheetcam or something else. Building a simple water pan and slats is not that hard, if you have a bending brake and/or welding equipment. If not having a metal supply place or heating/AC contractor build one will still be a little cheaper. It just depends on what tools you have and skills. You can always get by with a dry system and just a few simple slats then cut the water table parts and slats on your "dry" plasma table. Start by searching online then calling and emailing the smaller plasma table sellers and search the web sites of CNC electronic kit sellers like Automation Technology or CNCParts and get a better feel for your options and cost.
    Nov 2011
    263
    E-mail: [email protected] Web: www.elephant-cnc.com
    --------------Jinan Blue Elephant CNC Machinery Co., Ltd-------------
  1. Replies: 1
    Last Post: 01-01-2017, 09:58 PM
  2. Ball Screws for Plasma axis on 6 x 12 plasma table
    By Joe 66 in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 12-07-2015, 04:52 PM
  3. Replies: 0
    Last Post: 12-13-2014, 06:27 PM
  4. Precision Plasma Patriot 4x8 CNC plasma table
    By limekyle19 in forum Waterjet General Topics
    Last Post: 08-01-2013, 04:08 PM
  5. Replies: 10
    Last Post: 02-03-2013, 06:15 AM
