586,077 active members*
3,593 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > Super mini mill/coolant tank
Results 1 to 9 of 9
    Feb 2007
    19
    Has anybody figured out a way to keep small chips out of there coolant tank on the super mini mill. I also have a VF-2 and I run a system from chip trap on that one. The size of part and chips that I make are very small. And it seams like I have to clean out the tank on the mini mill once a month.
    Oct 2004
    84
    I thought about blocking off the slots that allow coolant to return to the tank. Then to build a shallow settling sump and filter arrangement and another pump to then send the collant back via a hose to the main tank.
    This return pump could be wired through a relay to be controlled by M8/M9 from the main collant pump circuit. Or, allowed to run a bit longer than M9 with a timer, but would then require logic to keep the pump on after M9 shuts down the main pump..... a latching relay??
    Dec 2005
    439
    where I'm at we have had chip problems with a few machines and a simple fix was to take a full sheet of scotch bright and cover the gate filter scrub it out as part of the morning routine works pretty well.
    I'm not lazy..., I'm efficient!
    HAAS GR-408
    Apr 2006
    97
    we use some pretty fine mesh over the drain holes simalar to that which is used on the filter gate on the pump we have made it removeable so that the mesh can be cleaned easily
    Jun 2004
    84
    Quote Originally Posted by taylors View Post
    I just put down some cut strips of the chip trap filters over the drain slots.
    That works very good.
    Feb 2007
    19
    Quote Originally Posted by duenow View Post
    Thats a good easy idea. I will try it.
    Scott
    Dec 2005
    439
    We tried this as well with less popular results, it was hard to clean the chips off the screen as the machine was running. The best we found was a hand broom to clean them and this still did not work great. What are you using to clean the chips out with?
    HAAS GR-408
    Jun 2004
    84
    Quote Originally Posted by automizer View Post
    The filters we just pull out after a while & put new ones in. The "Chip Trap" filters are cheap & I cut them & put over the "slots" cut in the Mini mill for the drain. I only run small parts & the chips are very small. The "Chip trap" filters are not a screen. That is one thing about the Mini mill that I don't like.
    Dec 2005
    439
    O I see. We had done something like that for a large run of Delrin but it came to much of a problem with the aluminum
    HAAS GR-408
  1. Engraving on an Arc using Haas Super Mini MIll
    By chop5280 in forum Haas Mills
    Last Post: 02-25-2015, 09:36 PM
  2. just my luck Set up a coolant tank
    By Rainman229 in forum Shopmaster/Shoptask
    Last Post: 02-26-2009, 06:18 PM
  3. Coolant Tank
    By GITRDUN in forum Haas Mills
    Last Post: 09-15-2006, 06:00 PM
  4. help with super mini mill please
    By daleman in forum Haas Mills
    Last Post: 08-14-2006, 08:32 PM
  5. part for super mini mill
    Last Post: 05-04-2006, 07:03 PM
