Hey just noticed I have a new issue that is not allowing the machine (VTC-16B) to run at the commanded feed rate that I have spec'd in Mastercam. I am commanding a feed rate of 175 in/min with a dynamic contour tool path that is a single line. The machine will not feed faster than 80.6 in/min even though the program is set at 175 in/min. Is there a parameter that is possibly set that is not allowing the commanded feed for whatever reason? Any help would be great thanks
