586,105 active members*
3,136 visitors online*
Page 1 of 3 123
Results 1 to 20 of 58
    Nov 2016
    109
    Custom pendant for Pathpilot
    Again some show and tell... I've had some downtime and decided to begin working on a pendant to speedy up my setups, as this is what kills my productivity. It is still very prototype and taking shape... if you couldn't tell. Its getting there.
    Love to hear some thoughts, here are my goals for the next proto:
    -Re-locate Start/Feedhold/Stop buttons to the top (I don't like them on the sides)
    -Make smaller and easier to wield (30-50% smaller is the goal)
    -Make some of the switches into dials (I think the overrides may be best into a selector switch, and possibly an independent XYZ axis selection rotary)
    -Add .0001"/.001" selections for step mode (maybe the others if there is room)
    -Add capability for zeroing axis'
    -Make it awesome (maybe a machined enclosure)
    Pete
    Jul 2004
    1424
    Re: Custom pendant for Pathpilot
    I have a Vista CNC pendant (P4s or something like that). What I don't like about it is that it does too much stuff.
    ok, it does nothing right now because of PP.
    What I mean is that having multiple switches that allow it to access dozens of different functions almost makes it like a combination lock. Something simpler with dedicated switches is better. I like your two pendant idea, but expand on that.
    Make the pendant on the right have dedicated feed, rpm, max velocity (three knobs) and three buttons (start, stop, feedhold). Separate buttons means it does what you want it to do. OW, maybe pushing feedhold changes the position of the feed override (maybe this isn't a problem).
    Since you have the feed/speed/max velocity override on the right hand pendant, do you really have to put it on the left pendant? Maybe replace those buttons with spindle start/stop button. Maybe add toggling the step between 0.010/0.001/0.0001".
    Tim
    Tormach 1100-3, Grizzly G0709 lathe, Clausing 8520 mill, SolidWorks, HSMWorks.
    Nov 2016
    109
    Quote Originally Posted by tmarks11 View Post
    Thanks for the input Tim. I like your combination lock analogy, that's exactly what it feels like when things get too crowded. There is definitely merit in keeping it simple. I still go back to the manual mills (laguns, bridgeports, etc) and how inviting the "controls" are. Every knob, dial, or button has a single purpose and is positioned in different areas of the machine, not on a single screen or pendant. It would be fun to recreate some of that stuff. For instance, a pull handle for the Z-axis. And since we have machine absolute position, maybe a button to set a "digital hardstop". I could go on
    Oct 2010
    670
    Hey Tim,
    I've been one of the folks testing the two pendants and here's my take on them. The two boxes serve two different functions. I use the larger box for my setup work (pretty much use every button on there during setups). Everything I need is right there (with the exception of the set zero----- hint, hint, hint - Pete) all in one unit. No going back and forth between two boxes or the keyboard/screen. Then once I'm ready to start running a part, I switch over to the smaller box since all I'm needing then is Start/Feed Hold/Stop and my overrides. Both boxes are plugged into a hub and I've had no issues with conflicts or anything.
    All in all, these two boxes are a 1,000% leap ahead of the jog shuttle, mouse, keyboard. It's killin me to have to send the beta test units back today. Thank goodness I'll be at Shot Show for a week and hopefully the pre-production three button control will be in when I return.
    Later,
    Awall
    The Body Armor Dude - Andrew
    Apr 2013
    1788
    Did you say that it is plug-and-play with no need to edit any PP files with each new release of PP?
    Oct 2010
    670
    Quote Originally Posted by kstrauss View Post
    It's a super easy patch that you apply. I updated to 1.9.7 then applied the single file patch. Nothing to edit line by line or anything like that. No harder than doing a normal update.
    Apr 2013
    1788
    That sounds perfect. Certainly far easier than following all of the manual steps to install the VistaCNC which, in the end, don't work!
    Nov 2016
    109
    The simplest way I have found is to where there is no editing, however, there is patching op, but it is straightforward. Takes about a minute, and smoke may be able to comment on ease.
    Every time there is an update to PP, it creates and pulls from a new directory. This negates the current version, and each successive version would need the new patch. I also got it to work through the standard "Update" button process that uses a ".TGP" file. But this new method is benign.
    Pete
    Apr 2013
    1788
    Using the normal PP update button with a .tgp file on a USB stick would be by far the most intuitive approach for non-Linux types.
    Nov 2016
    109
    Yea thats what I was thinking as well initially, but they do put some effort to keep people from making the .tgp files, which steered me this way. Plus I don't want anybody to confuse my projects as theirs. I come in peace.
    Apr 2013
    1788
    I wouldn't worry that people would confuse your addon product with PP! If you make it easy to install then many will purchase your product and perhaps Tormach will choose to distribute it and add support to the standard PP and you can retire rich and famous. Make it hard to install and your widget will be a flop.
    Nov 2016
    109
    I need more of your enthusiasm in the shop! It'll make you mad how easy it actually is, and if you ever find the need to "patchpilot", you will see. Ill go into more details when things are polished and tested.
    Pete
    Apr 2013
    1788
    I'm curious about your installation. Do you need to add an additional user space module as with the Shuttle or just edits to the HAL files?
    Nov 2016
    109
    No edits to hals, the projects you've seen are staying in generic-hid, just like plugging in a keyboard or mouse. As we've discussed before, it keeps you out of a lot of tweaks and settings that are probably plaguing development. My goal is to start simple.
    Pete
    Apr 2013
    1788
    So your pendant looks like a keyboard + mouse to PP and thus no special drivers are required? That sounds like a winner!
    Nov 2016
    109
    Exactly!
    Jul 2014
    51
    Is there any progress on this project?
    Oct 2010
    670
    Quote Originally Posted by hoecken View Post
    We're working on it. The small three button is about ready.
    http://www.cnczone.com/forums/tormac...h-forum-2.html
    Nov 2016
    109
    I apologize for the radio silence! Yes there is progress, albeit slower than I want, but it is happening. A lot of changes over the last week or two. The biggest challenge has been finding an enclosure to be exactly what I want. Unfortunately, its not out there. Deciding to go to a custom 6061 machined enclosure (I've got a CNC milling machine right?) has been the biggest change, and probably the biggest relief, now that I can do what I want. You are welcome to see the latest on the design with the attached files. This PDF (https://drive.google.com/file/d/0B1n...ew?usp=sharing) should be to scale for an 8.5" x 11". If you are ambitious enough; you can print and cut it out with scissors, I do this alot... it will give you a feel of the sizing and ergonomics I am shooting for. I apologize for the lack of details as most of the artwork is done in another format. If you have any questions just ask!
    Here are my latest notes:
    -The buttons around the MPG are X, Y, Z, COOLANT, STOP, PAUSE, START, ZERO around clockwise
    -The selector switch will have .0001, .001, CONTINUOUS, DYNAMIC
    -The three buttons next to the selector are FEED, RPM, MAXVEL select
    -The navi wheel controls JOG OVERRIDE slider, the center button selects RAPID/FEED speeds, and the outer arrows control directions.
    -The buttons on the side of the navi wheel are Z+ and Z-
    -I may add the JOG OVERRIDE control to the override group, I still want to play with some things.
    Pete
    3D model pic....
    Attachment 348316
    Nov 2016
    109
    I had a little free time to work on the pendant. Here is the start of artwork. I am hoping, if it doesn't cost too much, to put LEDs on all the selection modes. There is still a lot changes to do, but its taking shape. I am machining out the housing this week hopefully.
    Pete
    Attachment 348992
    Attachment 348994
Page 1 of 3 123
  1. CUSTOM M-CODES IN PATHPILOT
    By IMT in forum Tormach PathPilot™
    Last Post: 10-29-2016, 05:50 PM
  2. Pathpilot Pendant
    By Blaat in forum Tormach PathPilot™
    Last Post: 08-01-2016, 10:01 PM
  3. Replies: 0
    Last Post: 08-26-2015, 05:17 AM
  4. Custom open source EMC pendant controller
    By clocksandblocks in forum News Announcements
    Last Post: 11-16-2012, 12:15 AM
  5. Custom Pendant Build
    By TangentAudio in forum LinuxCNC (formerly EMC2)
    Last Post: 04-19-2010, 02:31 PM
