586,106 active members*
3,106 visitors online*
    Oct 2010
    670
    T-Slot Cutter Recommendation
    Looking to build some custom T-Slot fixtures using small T-Slots. I've heard that using a key cutter is the wrong approach. Anyone have a recommendation? Will be in a 1" aluminum plate using 3/8" T-Slots.
    Awall
    The Body Armor Dude - Andrew
    Dec 2013
    5717
    Re: T-Slot Cutter Recommendation
    A T-slot cutter has edge cutting capability, a keyway cutter does not. You want to buy a T-slot cutter
    Keyway cutter
    T-slot cutter
  1. T SLOT MILLING CUTTER PACKAGE 5 (ON WALTER CNC CUTTER GRINDER)
    By dharschman in forum Toolgrinding / Toolgrinding Machines
    Last Post: 09-13-2010, 06:25 PM
  2. Cutter recommendation
    By flyva in forum CNC Machining Centers
    Last Post: 10-17-2008, 02:35 PM
  3. cutting a slot with a t-slot cutter
    By cncuser1 in forum Mastercam
    Last Post: 09-10-2008, 03:02 AM
  4. How do I use a dove tool cutter & slot cutter
    By bobby1 in forum BobCad-Cam
    Last Post: 04-16-2008, 02:06 AM
  5. Need Laser Cutter/Engraver recommendation
    By keithwwalker in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 06-20-2007, 07:41 AM
