586,043 active members*
3,600 visitors online*
    Aug 2013
    14
    USB THC config missing THC box
    Hello,
    I decided to finally upgrade my homemade plasma CNC with a THC using the Proma controller.
    I have it all connected and the diagnostics are displaying the ARC OK, UP, and DOWN signals but the Z axis isn't moving while cutting.
    I did discover that if you have the Ethernet SS that there is the THC checkbox in the config screen but my USB config screen does not have this box.
    Is there something I'm missing?
    Edit: I am using v17fe plugin and Mach3
    Aug 2013
    14
    Re: USB THC config missing THC box
    I emailed Warp9 and this is their reply in a nutshell:
    The USS cannot support Mach3's THC function. You have to buy the ESS.
    I bought the USS almost 3.5 years ago and don't recall seeing the info about the differences between the two boards other than one hooks up through USB and the other through Ethernet. So for those with USS and want a THC, you're SOL.
    Warp9 will offer a swap at a cost.
  1. rs-232 pinout config
    By Michael82 in forum Fanuc
    Last Post: 02-05-2012, 02:08 AM
  2. Z-Axis Config
    By T_Brown in forum LinuxCNC (formerly EMC2)
    Last Post: 11-19-2011, 08:25 PM
  3. Need help with config
    By justin bowser in forum Mach Mill
    Last Post: 05-09-2011, 01:53 PM
  4. Need Help Config M3-M5 Camands
    By woody8750 in forum Mach Software (ArtSoft software)
    Last Post: 08-30-2009, 02:33 PM
  5. Config Mach3
    By rex2 in forum Machines running Mach Software
    Last Post: 01-26-2008, 10:52 PM
