586,102 active members*
2,433 visitors online*
    Oct 2005
    99
    1987 Mazak QT8 T2 control alarm 13
    Hello everyone,
    This lathe is fairly new to me, and is running on a 10 hp American Rotary phase converter that came with it when I bought it. It was running ok before this problem. Now when I try to home the X axis, I get alarm 13, servo drive. The drive is a TRS 50 B. There is a LED bar on the lower left (of the drive) that has bottom (number 4) lit, along with the top round (number 1) lit.
    I downloaded the drive maintenance manual, and it says TGOV motor overspeed. I don't know what that means. The axis barely moves when it alarms out.
    Attachment 346652
    I read a post of a similar problem on another board, and following that advice I reseated the encoder cable at the motor a well as at the drive.
    I also removed the cover plate on the encoder and there was some white corrosion I blew out. The wires were too short to get the circuit board out very far, so after blowing it out, I reassembled it. I was not able to see an encoder wheel, so maybe this is a resolver? I have no clue.
    I still have the problem.
    Also the ball screw is easy to turn by hand. I originally thought this might be an over travel condition, but the alarms say not.
    Any ideas would be greatly appreciated. Thanks!
    Followup. I wound up replacing the pickup unit on the X axis servo motor.
  1. Mazak MYSTERY. HOW do you clear this ANNOYING Mazak alarm??!!! NOBODY KNOWS!!
    By Mill&Lathe in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 09-03-2022, 01:55 AM
  2. Alarm 406 Memory Protect Mazak Nexus 510c Matrix Control
    By Elmer13 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-09-2016, 05:08 PM
  3. Mazak quick turn 35 Modell 1987 Serial No 71667
    By glorylight in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 02-27-2016, 02:54 PM
  4. Mazak QT-20 T plus Control Alarm
    By iominject in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 12-09-2011, 02:33 PM
  5. Mazak Mazatrol Control M1 -- Spindle Alarm
    By stephen21in in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 03-18-2009, 02:46 PM
