586,060 active members*
4,594 visitors online*
IndustryArena Forum > CAM Software > Vectric > Aspire > Running a 2.5d project.
    Jun 2012
    25
    Hi everyone. I am in need of some help with setting up toolpaths.
    I have started my first 2.5d relief carving on a piece of Cherry and I have a question about the next pass. I ran the first pass as a roughing pass with a 0.5" end mill. I left a 2.00 mm machining allowance. So each pass depth is 0.1". I am now trying to program the next pass but am stuck wandering if I should be doing another roughing pass or start a finishing pass with material left behind. I was planning on using a 0.25" ballnose end mill. Then on my final a 1/16 tapered end mill. Can some one help me out? I have attached photos image of first pass ran and simulated and planned second pass. My machine is not super heavy duty so I am trying to cut it right and not take to much that would cause bog down or tear out. Thanks everyone. Insight greatly appreciated.
    Apr 2004
    5737
    Re: Running a 2.5d project.
    You could do it either way. If you use a .5" ballnose to do the roughing, you won't have all those "stairsteps" to remove; the cutting will be smoother. I doubt that part has enough detail to warrant a 1/16" cutter; a 1/8" tapered ball endmill would work fine. In that case a second roughing pass certainly wouldn't be necessary, and it would go a lot faster. BTW, this looks like a 3D relief, not a 2.5d project, which wouldn't have rounded contours or require a ballnose cutter.
    Andrew Werby
    Website
    I agree, go straight to the tapered ballnose.
  1. Looking for 30 or 45 size CNC mill, project or running
    By autotechsteve in forum Want To Buy...Need help!
    Last Post: 04-21-2014, 01:26 AM
  2. The VIP Project is running to the end !
    By Laurent_parti in forum Videos
    Last Post: 07-05-2013, 04:31 PM
  3. running emc as a simulator, running out of ideas
    By CaptainVee in forum LinuxCNC (formerly EMC2)
    Last Post: 10-13-2012, 10:52 PM
  4. please help getting my first CNC project running
    By mioduz in forum Automation Technology Products
    Last Post: 01-11-2012, 09:43 PM
  5. Longest running project
    By ger21 in forum WoodWorking Topics
    Last Post: 05-29-2011, 09:28 PM
