586,103 active members*
3,482 visitors online*
IndustryArena Forum > CNC Plasma, EDM / Waterjet Machines > Waterjet General Topics > Plasma torch On OFF automatic solution and voltage
    Jan 2017
    Hi Everybody! I have build up CNC plasma , its done , but now is one problem . I have R-Tech I-Cut100 plasma , HF with pilot arc 100A max. Now I need switch torch ON/OFF automatically. No problem in software level , but problem hop wire/connect torch trigger wires with controller board. What the best way ? I tray connect to my controller board DC/DC relay DC-3-35V /DC 5-110V in 5-110V connect that wire which originally connects with trigger (no relay dead -too much volts I think because HF - maybe I'm not wright). Now is question how get solution for this problem ? Relay? contactor ? solenoid ( not very happy with this solution). Someone know how Volts come in this trigger wire ? (this note same wire who come to plasma electrode) . I very hope to Yours help.
    Mar 2016
    325
    Re: Plasma torch On OFF automatic solution and voltage
    There should not be a high voltage in the trigger (max 24V) unless You connected wrong wires. The trigger is simple button with the cheapest momentary switch inside.
  1. New Automatic Nesting Solution on the Market
    By CNCDuct in forum News Announcements
    Last Post: 03-19-2013, 02:56 PM
  2. Powermax 1250 with automatic 100A torch
    By bdrotaru in forum Hypertherm Plasma
    Last Post: 09-05-2011, 01:04 PM
  3. Torch arc voltage
    By Rbeckett in forum Hypertherm Plasma
    Last Post: 02-24-2010, 11:54 PM
  4. torch voltage and THC
    By stirling in forum Waterjet General Topics
    Last Post: 10-08-2009, 12:43 PM
  5. RoboTorch Automatic Plasma Torch Height Controller
    By Dennis Bohlke in forum News Announcements
    Last Post: 08-24-2006, 06:58 PM
