586,062 active members*
4,787 visitors online*
IndustryArena Forum > WoodWorking Machines > CNC Machining Centers > Windows Xp 32bits Xilog3 - Kvara on SCM 80 Tech Plus
Results 1 to 13 of 13
    Jan 2017
    6
    The Old Computer that uses Windows 98 died. then I start to migrate to Windows XP.
    First is the Xilog3 I have the backup of complete folders
    Seccond the Kvara I have the backup of complete folders
    Then I start a clean setup of Windows XP.
    I did the configuration to make Windows XP to behave as monoprocessor OS
    Install the Drivers
    Everything OK til now...
    I upload the files to
    When I try to Open the BaseMenu this Message Appears.
    Attach 1
    And Xilog as it shows on Attach 2
    Need Help, I try everything... Serial Ports are Working Flawlessly as Serial Cable has been tested with sucess...
    I apreciate any help....
    Service SCM BR Guest
    Re: Windows Xp 32bits Xilog3 - Kvara on SCM 80 Tech Plus
    Verify the COM on the PC and CN.
    Verify the file Xilog3.ini if the settings is COM correct and it is working correctly.
    Jan 2017
    6
    I have already check it for many times... it has the same configuration as it was in the old computer.
    Try modify xilog3.ini.
    Put ; in the third line and delete ; of the second line.
    Because I remember the baud rate correct is 9600
    Jan 2017
    6
    I think I found the error, there's a file, params.cfg, I couldn`t copy that file, it say that file is corrupt...
    that's the only thing is different between one folder to other...
    Jan 2015
    35
    Try to set to only one cpu core In msconfig( google it )
    Other thing could be com cable. Pin 2 and 3 must be switched in win xp.
    Jan 2017
    6
    Quote Originally Posted by dmitry83 View Post
    Thanks for answering my comment gently....
    One more question
    This Pin setup is made by software or Phisical?
    Regards
    Jan 2015
    35
    Quote Originally Posted by betancour View Post
    One more question
    Regards
    Phisical. On com cable from plc to pc are 3 wire. 2,3 and 5
    Jan 2017
    6
    Pins are swiched now but still have the same error
    Jan 2017
    6
    I`ve made everything that people recommend to do
    But still I can not make it work in Windows XP, I wonder if it`s possible to make a Win9X VM, and make it work with standart Virtualized Serial PORT.
    I apreciate the help
    Kindest Regards
    Jul 2014
    16
    Open the KVARA.ini file in the KVARA folder
    Nov 2018
    Quote Originally Posted by piratman1 View Post
    hi, help me
    The machine Scm tech 80 show Error 4118 , communication failure with CNC.
    lamhon
    Dec 2018
    Dears,
    The same problem, can´t run the Xilog3 on XP or on higher WIN. Betancour have you solved it?
  1. Morbidelli Author 500 running Esa GV Kvara 3.0 - missing password
    By novasune in forum Commercial CNC Wood Routers
    Last Post: 02-10-2018, 05:54 PM
  2. Kvara NC on Beam Saw - 'Magic' brand.
    By crewboss in forum Uncategorised WoodWorking Machines
    Last Post: 08-29-2017, 11:12 AM
  3. Do not run KVARA S500
    By piratman1 in forum Controller & Computer Solutions
    Last Post: 12-13-2016, 04:48 AM
  4. Xilog3 - how to create a mix help please
    By m9g in forum CNC Machining Centers
    Last Post: 01-02-2015, 06:09 PM
