586,070 active members*
3,514 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Tips for drilling wood?
Results 1 to 8 of 8
    Aug 2010
    43
    I mostly cut brass, but do some woodworking. Everything is fine except for simple drilling, in which with whatever drill/endmill or settings I try for hardwoods I get burning. MDF isn't as bad. I have a medium sized router with collets up to 6mm, and unfortunately it is fixed at 10,000rpm. Haven't figured out how to work the VFD yet.
    Thanks!
    Re: Tips for drilling wood?
    drill at 200+ipm
    Aug 2010
    43
    Ah. I've been using much slower speeds. I don't think my machine will go anywhere that fast, though. Maybe 40 ipm.
    Apr 2004
    5737
    If drilling is a large part of what you want to do, you might consider adding a drilling spindle outboard, which would go a lot slower. You can drill very small holes with your router, but larger diameter bits need to slow down from those speeds - or get in and out a lot faster.
    Andrew Werby
    Website
    Aug 2010
    43
    Yes, I don't see a simple solution here. I will see how fast I can run the Z axis - probably faster than I have it set at the moment. Otherwise I don't do that much drilling anyway, so I can simply spot with the mill, and then move the work over to the drill press.
    Apr 2016
    102
    Quote Originally Posted by robobass View Post
    Thanks!
    Are you peck drilling, it helps a lot in keeping the tip of the drill cool. what size holes are you drilling?
    Barrie
    Barrie @ Composite Specialities Ltd. using BobCAD V29 Mill 3 axis Pro, Geomagic Design, Bricscad V16 and MOI V3
    Apr 2009
    3376
    It's Wood,,,???? No need for a second operation,,figure it out by varying speeds,feeds,and cutters
    Why have a CNC if your not going to use it ?
    Yes,,the above post is spot on,and.......use air
    Aug 2010
    43
    I think I just have my rapid feed setting set way too low (27.5ipm) for the Z axis. I'll see how much I can bump it up. I drill sizes from 3 to 6mm, sometimes 25mm deep, using either peck or fast peck. For wood it seems like the slow retraction speed is where the burning is happening. I do have air, but don't need it for anything else, so I'd sort of forgotten about it.
    Thanks!
  1. OMNI CNC Wood ROUTER Operation Tips
    By omnicnc in forum Omni CNC
    Last Post: 07-09-2012, 09:37 AM
  2. CNC Wood Router Operation Tips
    Last Post: 05-30-2012, 04:17 AM
  3. CNC Wood Router Operation Tips
    Last Post: 05-25-2012, 09:34 AM
  4. corel draw tips - please help - engraving portrait to wood
    By mx_race in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-29-2010, 02:44 PM
  5. Help! X1 drilling tips required!
    By digits in forum Benchtop Machines
    Last Post: 05-04-2007, 12:20 AM
