586,100 active members*
3,113 visitors online*
    183
    Coiling Nichrome
    How should i go about coiling nichrome wire? i have a spool and need to coil it.... can i simply coil it on a bar on my lathe?
    Oct 2006
    125
    Quote Originally Posted by elogicca View Post
    Is it worth the trouble? Coiled nichrome is pretty cheap at www.infraredheaters.com. ($30 for enough to make 3 2 x 2 foot vacuum former ovens, IIRC.)
    If the money is an issue, you might look at Thurston James's book The Prop Builder's Molding and Casting Handbook. I think it has instructions for coiling nichrome wire, using a variable-speed electric drill, but I forget the details.
    Jan 2007
    355
    I used a 3/8-16 threaded rod, approximately 3 ft long to coil some Kanthal wire.
    Cut a notch on one end of the rod to hold the wire.
    Wrap a couple turns of wire by hand to get it started.
    Chuck the other end of the rod in a cordless drill/driver.
    Keep the wire taut, use low rpm and the wire will coil around the thread form.
    It's not easy, but it gives good results.
  1. Where can I buy Nichrome wire from?
    By ihkim in forum CNC Wire Foam Cutter Machines
    Last Post: 10-18-2012, 06:08 PM
