586,082 active members*
3,758 visitors online*
Results 1 to 6 of 6
    Sep 2008
    4
    fanuc 18-m 1007 code
    Hey guys,
    We have a Johnford DMC-1200 with the 18m control. This morning when I fired it up, I got a 1007 counter sensor alarm. I have never experienced this alarm before and I am unable to find any information regarding it. Any information would be greatly appreciated.
    Feb 2015
    161
    Re: fanuc 18-m 1007 code
    That is a machine side alarm. Check the "A" bits in PMC status to find which one in on, then search the ladder for that coil and find what causes that coil to be on.
    Dec 2015
    171
    I @millguy, can you please help regarding johnford DMC 1200 machine i/o card VPA002B. IN MY machine it's pcb is burnt. Do you have any information regarding this board or schematics of the boards. Please help me if you can do. Thanks in advance.
    Dec 2015
    171
    Please check the picture
    Jan 2013
    474
    Quote Originally Posted by Mill Guy View Post
    Hey guys,
    This is a PLC alarm, written by Johnford. You should have a manual with these errors listed. I have found 1007 to be tool clamp switch, axis limit switch and even an emergency switch. The error states "counter" which could be an axis. You need to search the 1007 in the PMC ladder and see which input has latched on the fault, then refer to the wiring diagrams. Or email Johnford service for help. Alternatively, check each switch in turn
    Jan 2013
    474
    Quote Originally Posted by phucrobusl View Post
    That is a seriously burned I/O card, must have been a dead short from a switch or an output. You need to find the cause of this before fitting a new card or you'll fry it again. Get part number from machine information list or OEM and search eBay etc for a replacement.
  1. Replies: 7
    Last Post: 01-30-2023, 01:58 PM
  2. UL-1015 and 1007 source in Taiwan.
    By dmannock in forum Chinese Machines
    Last Post: 08-05-2015, 10:44 AM
  3. Need Help alarm 1007
    By DanMatei in forum Fanuc
    Last Post: 08-09-2012, 08:48 AM
  4. YANG VMC1000 OM-D ALARM 1007
    By Toddxmann in forum Fanuc
    Last Post: 04-23-2009, 11:12 PM
  5. Femco 1007 External Alarm
    By Femcos rule in forum Uncategorised MetalWorking Machines
    Last Post: 10-14-2008, 07:30 PM
