586,103 active members*
3,859 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > im almost done with my DYI 5 axis machine but i have this noise issue....
    Jan 2016
    33
    My motors start jittering and moving on there own. every other 10 seconds or so. i Finally think I've pin pointed the problem And want some advice from this great community.
    I have some gecko 214 drives running these things and every time i plug the 5 volt logic into them that's when the motors start moving on their own without any pulses given to them yet.
    I ended up buying an oscilloscope. but I'm an extreme noob at using it. Either way, look at the images below. I get alot of noise on the 5 volts going to these geckos whenever i plug in the power supply.
    It seems like everytime those spikes happen the motors want to move a bit. How can I get rid of those spikes? I almost have this thing running perfectly except for that.
    here is a little clip of the machine in motion if your interested. Help me finsih this thing up!
    this is the power supply im using.
    http://www.antekinc.com/content/PS-4N58R.pdf
    and the controller if it makes any difference.
    HiCON Integra - Step and Direction 6 Axis Mach3 Mach4 Ethernet Motion Controller, CNC Retrofit, Machine Tools
    and here is a schematic of some of my wiring.
    thanks!
    Jun 2012
    108
    Re: im almost done with my DYI 5 axis machine but i have this noise issue....
    Looks like a nice scope.
    You said ".....every time i plug the 5 volt logic into them...." If you are readily plugging something in and out that not a fair test. Thing will change. What you need to do is put one probe of the scope on the motor that is moving and use that wave form to trigger the scope to capture the signal of the other probe.
    Ex. The motor moves and trigger the scope the other probe is on one of the input of the driver, did the wave form change, if not then look at the next point to see if it is moving.
  1. Apparent noise issue
    By spank in forum Dynomotion/Kflop/Kanalog
    Last Post: 12-13-2013, 11:17 PM
  2. Need help with electrical noise issue
    By b42000 in forum DIY CNC Router Table Machines
    Last Post: 07-18-2013, 02:47 AM
  3. Noise reduction issue!
    By Barefootboy4 in forum Mach Software (ArtSoft software)
    Last Post: 09-15-2011, 12:40 PM
  4. Need help please, crazy noise issue.....
    By pete from TN in forum Benchtop Machines
    Last Post: 04-13-2010, 11:17 PM
  5. Motor Noise Issue
    By dsnellen in forum CNC Machine Related Electronics
    Last Post: 01-26-2010, 03:36 PM
