586,036 active members*
3,558 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > What dip switches to set on Stepper Driver board?
Results 1 to 9 of 9
    Jan 2017
    39
    Hi all,
    I'm brand new to all this CNC stuff and so far loving it!
    I've got NEMA 34 stepper motors, The name plate says 5.6A.
    http://www.cnczone.com/forums/attach...d=347294&stc=1
    I'm using the following type of driver...
    http://www.cnczone.com/forums/attach...d=347296&stc=1
    These have got dip switches on. Currently I just have all the dip switches ON (which equates to 400 pulse/rev and 2.8A Peak current).
    http://www.cnczone.com/forums/attach...d=347304&stc=1
    I'm not sure what these switches are meant to be set at? Am I meant to have the power ones set to 5.7A Peak or set to 5.6A RMS ??
    Also, what difference does the pulses/rev make? Is the more pulses per rev linked to the accuracy of the motor? In which case do I just want it set to the maximum?? Or is it software dependant?
    I'm using LinuxCNC to send the g-code to my motors.
    (Currently I don't have the motors on a machine - they are just sat on the floor and I've just been testing the connectivity etc).
    Also worth noting that I'm just in a domestic property and not an industrial environment so don't really want to be pulling lots of Amps down my mains (plug fused at 13A anyway).
    Any help would be greatly appreciated.
    Re: What dip switches to set on Stepper Driver board?
    You're showing two different drives, with different settings?
    I'd set it to 4.9A peak, and either 1600 or 2000 Pulse/Rev.
    You need to set up Linux CNC to send the correct number of steps to match your setting on the drive.
    Higher steps/rev makes the motors run smoother, but it's generally considered that you don't need more than 8x-10x microstepping (1600 or 2000 steps/rev)
    Jan 2017
    39
    Yep, the first picture was just a 'stock' picture that I got from Google to just show the type of driver. The second pic is my actual driver.
    I didn't notice the difference! Well spotted Gerry!! You have eyes like a hawk sir! :-)
    Thanks for this info Gerry (as always). I just wondered why you settled on 4.9A peak? Is there some sort of formula to do with steps/rev or something else that leads to 4.9A?
    Thanks again :-)
    You can probably use the 5.7A setting, but I usually use a little less than the rated current, and that's the next lower setting.
    Jan 2017
    39
    Thanks Gerry. I've change all the dip switches and changed the settings in LinuxCNC but this has created a couple more questions if you don't mind...
    The stepper driver has the following info provided in the manual (which is in German unfortunately for me)...
    Attachment 347344
    I took this to mean that in LinuxCNC the following settings were needed...
    Step Time: 4500ns (the 2500ns at the bottom of the pulse step added to the falling edge and rising edge of 1000ns each?)
    Step Space: 4500ns (same as above?)
    Direction Hold: 1500ns (the 2500ns between PU and DR minus the 1000ns falling edge?)
    Direction Setup: 5500ns (the 3500ns between the DR and MF signals added to the falling/rising edge of 1000ns each?)
    Am I right with this or am I working this out wrong?
    Also, in LinuxCNC for each axis they ask for the "Maximum Velocity" and "Maximum Acceleration". I've no idea what to put in here. So far I've just put in 25mm/s (1in/s) for velocity and 750mm/s (29.5in/s) for max acceleration.
    Any guidance on this would be most welcome. Thanks
    Dec 2012
    199
    Your stepper driver DQ542MA will most probably work without problems on the default values from LinuxCNC
    Your motor has 6.5mH inductance.
    with 36 volt supply to the driver that gives a maximum speed about 275 rpm if your spindle is 5mm per rev it comes to 1375mm/min so about 23 mm / sec ( your 25 is a good value )
    at 48 volt supply the values are 370 rpm 1850 mm/min 30 mm / min
    the value for acceleration depends also on the mass that needs to be set into move. just try out some values on your machine and when loosing steps, set a value realy below ( -25 % or so )
    Jan 2017
    39
    Ok thanks for the help. I'll wait until the rest of the machine is built and then do a bit of experimentation. Thanks again :--)
    Feb 2017
    15
    Hi J, Did you find any info on what/how ip switches should be configured. Sort of got the part about AMPS but what about Resolution and Smoothness? Best, Jono
    Jan 2017
    39
    Quote Originally Posted by Jono888 View Post
    Hi Jono
    I've currently got it set to 4.9A peak and 25,000 steps per rev. ** Disclaimer ** - I've not currently got the motors connected to the machine (because I've not built the machine yet - I'm still finishing off the control panel. So I may need to change these settings when I actually start trying to router something out.
    If you get any more info on this then please post back in this thread as I think there is a lot of this that's going to be a bit of trial and error. :-)
  1. stepper motor board that has both mcu and driver and API
    By Hartsai in forum Stepper Motors / Drives
    Last Post: 05-04-2015, 09:45 AM
  2. stepper driver and Breakout Board
    By hennies1 in forum South Africa Club House
    Last Post: 09-27-2013, 10:37 PM
  3. THE Stepper Driver and THE Distribution Board
    By NorDevX in forum News Announcements
    Last Post: 09-13-2013, 03:07 AM
  4. Stepper driver board
    By 4lowie in forum Australia, New Zealand Club House
    Last Post: 09-09-2011, 09:31 AM
  5. 6 leads stepper motor connect to TB6560AHQ stepper driver board
    By wf1318 in forum Stepper Motors / Drives
    Last Post: 07-25-2010, 08:19 AM
