586,112 active members*
3,128 visitors online*
Results 1 to 9 of 9
    May 2006
    214
    System variables
    Is there a special parameter I need to change to be able to see the
    System Variables. (#1000 and up)
    I see Locals and common up to #531 and that's it.
    My lathes are Fanuc 18T
    Regards
    George
    2932
    As far as I know you have to assign the system variable to a local variable and check it there, or use a DPRNT to output the system variable to whatever's hooked up to the serial port.
    May 2006
    214
    That's a tough one.
    I'm new in macros, I did not quite understand what you're telling me
    Can you please rephrase.
    Regards
    George
    24221
    Check to see if you have parameter 9937 bit #4 set xxx1xxxx.
    This can be for variables 149-199 & 531-999
    Al.
    Albert E.
    May 2006
    214
    Sure I will do that, something like this??
    00010000
    I hope I can find out for the System variables #1000 and up, they really can make a lot of stuff.
    Thank you all.
    George
    I
    24221
    I am not sure which ones you mean by #1000 up, as far as I can tell the 18 & 18i show 100 to 199 and 531 to 999 for variables by option.
    Al.
    Albert E.
    2932
    In MDI, key in #101=#4007, EOB, INSERT, and Cycle Start. You can then look at 101 in the MACRO variables and see the value of system variable 4003. #4003 is the active G code of the 07 group (G40, G41, G42), so you should see a "40" stored in #101.
    24221
    AFAIK if you have macro option then you should have access to the system variables, read only.
    Active G codes, as mentioned, and servo positions etc etc.
    Al.
    Albert E.
    May 2006
    214
    Ok guys this is getting rough.
    I think I'm going to start from the bottom.
    I'm a beginner in this...I'll start with small programs before I get to macro
    functions and stuff like that.
    Thank you all for your help.
    Cheers
    George
  1. Variables/Macro uses....
    By theemudracer in forum Fanuc
    Last Post: 12-13-2006, 08:45 PM
  2. G65 local variables help
    By FanukRC in forum G-Code Programing
    Last Post: 07-26-2006, 12:00 AM
  3. Hitachi Seiki Seicos MYII control system variables
    By pieface in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-21-2006, 07:45 PM
  4. Need detailed information for system variables on Fanuc0m control?
    By Alf012 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-03-2005, 07:52 PM
  5. Mori Seiki MF-T6 System Variables
    By EvilScooby in forum Uncategorised CAM Discussion
    Last Post: 06-13-2003, 01:32 AM
