586,108 active members*
3,196 visitors online*
    Apr 2015
    16
    Mach 3 auto calibration problem
    Hello folks,
    I have just finished building a large gantry style CNC and I am in the middle of calibration. The problem I am having is that because of how I built my table I needed to use two motors for the 8ft Y axis. So in Mach 3 It was easy enough to set up the other motor (b) as a slave to Y and I can sync their movements just fine, but now that I am trying to auto calibrate the step count the auto calibrate only moves one axis at a time, which is no good because it will skew the table. Do any of you know of a way to get the auto calibrate to do this? Or does anyone have enough knowledge to tell me where to tweak the API perhaps? I don't think it would be very difficult to add a few lines of code that would allow a user to select a drive and hold down shift to select a slave drive to auto calibrate.
    Thanks in advance for any help.
    Re: Mach 3 auto calibration problem
    There's no way to use the calibrate on a slaved axis. Just do the math to calculate the correct steps.
  1. Mach 3 Axis Calibration
    By Teepaco in forum Screen Layouts, Post Processors & Misc
    Last Post: 04-20-2016, 04:43 PM
  2. Question about mach 3's steps calibration
    By streetrodlover in forum Avid CNC
    Last Post: 04-14-2015, 12:28 AM
  3. Mach 3 Axis calibration (Benchtop Pro)
    By Semus in forum Avid CNC
    Last Post: 02-05-2015, 12:34 AM
  4. Spindle calibration with Mach, VFD, and a G540
    By Pplug in forum DIY CNC Router Table Machines
    Last Post: 10-13-2012, 01:49 PM
  5. Mach 2 Axis calibration
    By mikie in forum Mach Software (ArtSoft software)
    Last Post: 08-17-2005, 01:19 PM
