586,113 active members*
3,207 visitors online*
IndustryArena Forum > Events, Product Announcements Etc > For Sale Only > Sieg SX2P milling machine in great condition with many perks (Edinburgh UK)
    Apr 2012
    4
    Please see Gumtree add with pictures here:
    https://www.gumtree.com/p/other-powe...rks/1211887088
    I am selling my Sieg SX2P HiTorque Mill with upgrades and tooling.
    The mill is the one sold by ArcEuroTrade (UK), product number
    080-030-00300. The mill has been upgraded with the large table (SX1L) and the LittleMachineShop air piston to support the head. The mill features a belt drive that is quieter and more resilient than gears. The spindle motor is a 500W brushless motor.
    The mill is in great condition, purchased on the 28/7/2014 with some 100 hours of use. You will get a copy of the purchase receipt as well as the machine's instruction manual. The mill has an R8 metric type spindle.
    Together with the mill you get:
    - All tools supplied by the manufacturer (spanners, allen keys etc)
    - Purchase receipt and Instruction Manual
    - Protective cover
    - ER20 12-piece collet set ( 2-13 mm) from GlosterTooling UK
    - ER20 R8 collet chuck ( 7/16”UNF drawbar) in its box and collet nut spanner
    - Unused mechanical edge finder in its box, 10mm shank, 4mm tip, 90mm length
    - Set of RUKO M3 taps
    - 4 tap wrenches
    - Jacobs chuck (up to 13mm drill bit) with R8 arbor as supplied with the machine
    - Unused spring tap guide in its box
    - Dial test indicator in its box, 0.8mmx0.01mm
    - Stuarts micrometer blue (engineer's blue)
    - 2x Stevenson’s Metric 10-20-40 Blocks (10x20x40mm M6 Tapped & Clearance)
    - Large right-angle block
    - 300mm vernier height gauge and scribe
    - magnetic base with dial indicator
    - virtually new spray bottle of WD-40 cutting fluid
    - spray bottle of white lithium grease
    - virtually new bottle of Mobil 1 oil
    - 4-piece engineer's square set in box
    - 24pc Clamping Set 8mm (M6 thread)
    Happy to answer questions. The bench the machine is on is also for sale. It is a hardwood top, 1.8 m long, heavy duty powder coated steel frame bench. The machine is positioned at one end leaving about 1.5 meters of workspace. I have added an oil, solvent, impact and puncture resistant rubber top. Please ask if you are interested as they make a nice combo.
    Apr 2012
    4
    Re: Sieg SX2P milling machine in great condition with many perks (Edinburgh UK)
    Gone now.
  1. Sieg X3 Milling Machine CNC Conversion Project
    By Bird_E in forum Vertical Mill, Lathe Project Log
    Last Post: 11-30-2009, 05:31 PM
  2. Sieg X3 CNC Milling machine for sale
    By Charles09 in forum MetalWork Discussion
    Last Post: 06-13-2009, 01:24 AM
