586,103 active members*
3,222 visitors online*
IndustryArena Forum > MetalWorking Machines > EMCO CNC Machines > Compact 5 with closed loop servos and linuxcnc
    Jul 2003
    1754
    we have a few compact 5 cnc with dead controls. There where some surplus pittman servos we bought a few year ago - small but had some heds 500 line encoders. Thought we could use them for something..
    We mocked up a setup to see if the pitman motors where big enough. They seem to be.
    -5i25 with a custom bit file that has pwm/dir on one plug and encoder counters on the other.
    -pwm/dir input AMC servo drives 15 amp 80v (the servos are rated at 24v)
    -cheap BOB
    after hacking a config
    Attachment 347528
    Pretty darn happy - with that simple setup - we are getting .0002 following error. They seem to have more than enough power. (the testing was done with a 1amp 25v supply.) Currently 150ipm
    sam
    Jul 2003
    1754
    Re: Compact 5 with closed loop servos and linuxcnc
    Linuxcnc -> mesa 5i25 pwm -> Bob -> AMC drive -> Servo -> Encoder -> mesa 5i25 encoder counter -> Linuxcnc
    I have the pwm set to 20khz
    I have actually tested this setup - and others have actually run it using the printer port. You loose the high frequency pwm and its higher levels plus you have to be aware at your max encoder counting speed. But it does work.
    Here is the adapter we made to go between the servo shaft an the timing gear.
    Comparing the servo to the stepper
    Aug 2003
    318
    Nice job. I have a pile of those motors. They work well for all sorts of motion projects. I like em.
    Donny
    Jul 2003
    1754
    just testing - proof of concept....
    .00008 following error....
    Attachment 347838
  1. Replies: 0
    Last Post: 09-15-2016, 10:54 AM
  2. Closing the loop with Path Pilot. Possibly dual (global) closed loop?
    By SwampDonkey in forum Tormach Personal CNC Mill
    Last Post: 05-04-2016, 09:39 PM
  3. Replies: 0
    Last Post: 03-13-2012, 11:15 PM
  4. plasma table retrofit: smart servos or closed loop steppers?
    By Josh Leber in forum Waterjet General Topics
    Last Post: 03-25-2006, 04:25 AM
  5. Closed Loop Driver vs. Closed Loop Computer
    By ojibberish in forum Gecko Drives
    Last Post: 06-08-2004, 05:30 PM
