586,058 active members*
3,435 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach3 - Homing speed much much slower than jog speed
    Nov 2016
    7
    Hi all. I'm starting to get my 3040Z-DQ machine to behave properly with Mach3.
    I notice that the jog speed (for every axis) is wonderful for a motor tune velocity of '150' (which is in the motor tuning setup window). Nice and quick. Flawless.
    But, when I use the homing feature of Mach3 (for automatically taking the spindle back to a home location such as machine coordinates x=0, y=0, z=0), I can see that the travel speed of returning-to-home is very very slow (when compared with the cursor-key jog speed).
    To temporarily get around this, I went into the motor tuning window to increase the speed from '150' (which was a value recommended by the user's setup manual for my 3040Z-DQ machine) to a new value of '2000'.
    With a speed setting value of '2000', the homing speed is much improved - and appears satisfactory. So, the homing speed becomes normal with a setting of '2000'. However, with this setting (of '2000'), the jog speed then becomes so fast that the motors (or something) lose sync, where the sliding rails just halt, and very loud whining/wailing sounds occur - which forces me to shut off the motors before I do any nasty damage.
    Then, to overcome the jog speed being too fast (with the motor velocity setting at '2000'), I then hit the 'TAB' key and then manually set the jog speed to 10 percent.
    Can anyone let me know if the above is approach is satisfactory for setting up Mach3?
    What I'm confused about (being a newbie and all) is....... why is jog speed at a good speed to begin with (ie. with the original velocity setting of '150'), while homing speed is slow? I was assuming that homing speed would be the same speed as 100% jog speed. I can see that (for my case) - the homing speed is clearly much different from 100 percent jog speed.
    Thanks for any comments and help!
    Re: Mach3 - Homing speed much much slower than jog speed
    Homing speed is a percentage of the Velocity in motor tuning. You can change the homing speed percentage in Config > Homing/Limits.
    Nov 2016
    7
    Thank you very much for your help Gerry! Greatly appreciated! Thanks again.
    [UPDATE]
    Also - you helped me to finally realise that the 'speed%' value IS the 'homing speed'! I had initially and incorrectly assumed that this particular speed% setting parameter was the speed for the 'slow zone'.
  1. Help! k40 Laser Engraves Slower than Speed Setting
    By Cjjones in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 07-06-2015, 08:03 AM
  2. RS232 file speed - much slower than should be?
    By nzben in forum Cincinnati CNC
    Last Post: 06-09-2012, 11:17 AM
  3. Is actual cutting speed slower or curved than straight lines?
    By zachary2001 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 04-27-2012, 11:34 PM
  4. Slower Jog Speed
    By rweatherly in forum Screen Layouts, Post Processors & Misc
    Last Post: 11-18-2006, 07:33 PM
  5. Homing speed
    By jgro in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 05-30-2004, 11:49 AM
