Re: optimal clearance ?
indeed arie, anyone wishes for rigidity, but sometimes there may be a weak fixture, or overhang on tool , or whatever
lately some o350 x 550 parts needed external turning with 0.02mm tolerance, after deposition of a hard layer, that simply distroys carbide inserts after 30-50mm, while better diamond tipped inserts would last a few complete passes, but with wear corections among the way
for example, final radial docs are like 0.3 0.2 0.1 0.07 0.05 0.02, while offset corections are aplied, and, to achieve the last 0.02, the tool offset is raised with 0.2mm, or something, thus, in orider to go deeper, the tool is raised there is no linearity between offset and real doc, as the normal aproach was initialy grinding, which is much more stable and finess
as passes are relativley long duration, is easy to loose track of corections, so a log is being kept
this is just a particular example, as, in general, every setup has an elastic and plastic behaviour; and rigidity occurs when elastic behaviour does not affect the tolerance but of course it drives me crazy, i wanna throw the thing in the dumpster, like you said .... but i just have to get it done, what choice do i have ?
.I used 2 mm on the Bridgeport VMC 800, 1000, 600, 610, Interact, Oerlikon Vector, Schies & Froriep, Kiheung, Basically every Heidenhain Operated Machine i ever worked on, but i also used the same 2 mm on Elora controled machines, and on Cincinnatti and Fadal Controls..
the background of the clearances that i discused here, is in conjucton with okuma's codes; is a result of long term homework about cycles times shortening technique, trigering seconds, tens of a second, or even less, each time scale having different aproaches
