Originally Posted by
deadlykitten
V1 = 9.388 when M331 is not there
V1 = 7.133 when M331 is used once
V1 = 0.368 when M331x6
V1 = 0.001 when M331x18; definetly rocket science
hello past self of my self : it seems a bit weird to obtain different values for V1, but actually is not
in this code :
Code:
N1 G00 safe position
N2 G00 X200 Z+2.5
( nothing, M331 once, or M331 many times )
N3 NOEX V01=something with VAPAX V02=something with VAPAZ
N3 will be executed only after previous line has confirmed it's execution
normally this happens after "|axis_position-progam_position|<droop"; in other words, when N3 is executed, movement from N2 did not finish
if you put 1 or more M331 codes, you simply delay the execution of N3, and during this delay, movement from N2 continues even futher
if you put many M331 codes, the delay will allow the axis to reach the coordinates from the program, and, like this, ipw becames 0
i needed to be sure that a colision does not occur, without increasing the clearance distance
well, now i know the answer
in this code :
Code:
N2 G00 X200 Z+2.5
N3 G01 Z-50 feed
if rapids are high, when feed begins, X axis won't be at 200, but maybe at 210 ?!
if feed is low enough to allow X droop to minimize ( thus to move from 210 to 200 ) until cutting edge reaches the part, then you won't crash the cnc
otherwise, you will crash it
for example, this code, where a drill is going in rapid inside a part, will crash, because clearance is low, is executed fast, thus there is no time to minimize the droop
Code:
N2 G00 X200 Z+1
N3 G00 Z-50
in other words, when low clearances are used among an axis, it is required to be sure that the clearance is still long enough to allow the droop of the other axis to minimize
another example : if threading ( among Z ) is done without a thread relief, and X clearance is low, and rapids are high, then the insert may cut during repositioning ( check attached )
kindly
