586,103 active members*
3,404 visitors online*
    Apr 2015
    16
    Bent screws or something else?
    Hello all,
    I am getting a crazy amount of deflection on my y axis movement. I am running two ball screws setup on the outside of the table to move the gantry (8 ft). I think that the screws are bent but before I replace them I want to make sure it's not something that the machine will just do again. I have been reading up on the importance of ballscrew end fixity and it appears that my current setup is almost the least ideal. I have attached pictures of it. It appears that both ends are supported and not fixed. Can someone tell me if that is correct or am I missing something?
    Thanks!
    Dec 2013
    5717
    Re: Bent screws or something else?
    You have to have at least one end of the ballscrew fixed or you will have axial movement in the assembly, not good. The most common way is to fix and preload the motor end and allow the other end to float in the support bearing housing. I have seen both ends being fixed where the ball screw is placed in tension and preloaded between the support bearings.
  1. Frustrated with bent Y axis lead screws on SX2.
    By tjbaudio in forum Benchtop Machines
    Last Post: 09-29-2014, 12:56 PM
  2. Regular ACME Lead Screws Vs Precision Screws?
    By FreshMint in forum DIY CNC Router Table Machines
    Last Post: 11-27-2011, 03:51 PM
  3. Bent ball screws and rods
    By Drakkn in forum DIY CNC Router Table Machines
    Last Post: 09-04-2010, 04:40 PM
  4. Bent Too Much?
    By Mr.Chips in forum DIY CNC Router Table Machines
    Last Post: 02-20-2009, 05:25 PM
  5. Ball screws, Acme screws, threaded rod
    By DJ Morrow in forum DIY CNC Router Table Machines
    Last Post: 03-22-2007, 06:39 PM
