Re: Fly cutting table surface
Originally Posted by
Jim Dawson
I would not want to use a fly cutter at router speeds, if that tool bit comes flying out at 10,000+ RPM it would be like a bullet. :nono:
I use a 1.5 inch flat cutting router bit like you show above. Observe the maximum rated RPM on the bit you use.
Yes, exactly why I was inquiring... those things scare me.
Would you have a problem surfacing a small section of aluminum with that same bit? I have a touch off for bit changes built into the table, 2 x 2 square, and should be surfaced with the table.
Thanks for the post.
Gecko G540, Rack and Pinion Drives-X and A axis, 1/2-10 5 Start Acme-Z Axis
4-THK HSR 25 Linear Slides, KL23H2100-35-4B, Power Supply-KL-600-48 48V
