586,043 active members*
3,782 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > v28 Post Processor Helical Arc Output
    Oct 2005
    420
    Hello,
    Was hoping someone could help me out with modifiying my post processor to output helical arcs in a separate format than regular arcs. I've looked thru my post and expected to find a section that might be just for helical output but so far no luck. It might be under my nose and just overlooking it. I know most machine controllers will just use the same format as a regular arc (G2, G3 X Y Z IJK) and just put a z value in. My controller (Bridgeport DX32) will "work" in this fashion but causes problems as, according to the manual, am supposed to use a G13 or G12 rather than G3 or G2 (but only for helical).
    I've been using it in standard "fanuc" format but at the bottom of the helix it will drop about 10-15 thou and make a loud bang. Very hard on cutters, the part, and probably not great on the machine.
    According to a former BP engineer, there was a glitch in the control software that caused this and was never fixed.
    I've attached my post processor.
    Nate
    Oct 2005
    420
    Re: v28 Post Processor Helical Arc Output
    Is this something that could be done thru scripting? Anyone else had a similar situation with thier machine controller?
  1. Post Processor: Changing the format of feed output.
    By somebodyelse in forum CamBam
    Last Post: 01-16-2014, 03:33 PM
  2. Helical output I,J,K
    By seven3 in forum OneCNC
    Last Post: 10-31-2013, 05:41 PM
  3. Output Feature Name in Post Processor
    By Alf0412 in forum BobCad-Cam
    Last Post: 07-30-2012, 08:44 PM
  4. MC post processor output format
    By garyong in forum Post Processors for MC
    Last Post: 04-14-2011, 07:36 AM
  5. Post processor output in conversational?
    By klrskies in forum BobCad-Cam
    Last Post: 07-02-2010, 12:27 AM
