586,530 active members*
2,744 visitors online*
IndustryArena Forum > MetalWorking Machines > Smithy > Proof that the VMC425 exists!
Results 1 to 16 of 16
    Aug 2007
    701
    Jul 2004
    1424
    Re: Proof that the VMC425 exists!
    Maybe my eyes deceive me, but it looked like they were using the "tormach tool system" instead of a real cnc tool taper.
    Not sure how well a 3/4" straight shank is going to hold up with a 10 hp spindle....
    Tim
    Tormach 1100-3, Grizzly G0709 lathe, Clausing 8520 mill, SolidWorks, HSMWorks.
    Nov 2003
    287
    It appeared the tool holders are tapered with a pull stud. At least in the first video
    Jan 2017
    BT30 Taper.
    Jan 2013
    630
    Other than having more horsepower than I would need for home use the size and features are pretty good. A little more X axis travel would be good. It has less the by BF20L. Doesn't appear to have that large of a foot print. If it's priced right I could see owning one.
    It does not in any way have a 1.3 second chip to chip tool change however as stated in the video.
    Jul 2004
    1424
    Quote Originally Posted by vertcnc View Post
    Yeah, you are right. I missed the scene where he installed the toolholder manually.
    Attachment 348046
    Smithy has been busy. They have a bunch of new youtube videos up for other machines. And in Smithy's tried and true process, the machines in all their videos have completely different names than the machines on their website.
    Tim
    Aug 2007
    701
    Quote Originally Posted by kerryballard View Post
    BT30 Taper.
    Since Kerry works for smithy - I would go with his answer for the spindle taper.
    Kerry do you have a link to the specs and pricing?
    Thx!
    Jul 2004
    1424
    Smithy just updated their website, and it now has the VMC425, MX200, and updated pages for their cnc lathes.
    Tim
    Nov 2012
    145
    Anyone know when the other ones are coming out with the larger travels? And I belive in the walk around video he says it has a 12 station atc.
    Mar 2013
    131
    Quote Originally Posted by tom o View Post
    I was just reading the specs on here https://smithy.com/automatecnc/vmc425 and it shows a 10 station ATC. It also show the $23,000 Talon MT300 PRO having the 12 station ATC.
    Jun 2013
    25
    Hello Eltejano tom o
    Larger machines are available now, but more or less built to order. The machines highlighted on the website are the ones we keep in stock.
    The 425 comes standard with a 10 position ATC. The VMC500 and up can be outfitted with a 16 tool arm style changer.
    Nov 2012
    145
    Quote Originally Posted by kadesmithy View Post
    Thanks for the information! A 10 tool ATC would suit me just fine they probably went with that one due to the enclosure. The specs say the dimensions are 81"x70"x87" is 87" the max height I have a garage door height of 82" max, what is the minimum height of the 425?
    Jun 2013
    25
    Hello Tom,
    To the highest point of the machine measures right at 82 inches. That highest point is the Z axis motor. This can be removed by loosening 4 socket head cap screws. With the motor removed, you will clear without issue.
    Have a great day!
    Jul 2003
    19
    Are there any actual VMC425 owners in this forum?
    Aug 2007
    701
    This forum is a little sparse now that the facebook group is up and running. Head over to the AutomateCNC group on Facebook and there are guys there w/ the VMC425.
    Jul 2003
    19
    Thanks brianbonedoc!
  1. cant believe nothing exists in this catagory, i just cant believe it!!!
    By manakawari in forum Material Machining Solutions
    Last Post: 09-03-2016, 05:33 PM
  2. What affordable 4/5 axis CAM exists?
    By MarcusWolschon in forum Uncategorised CAM Discussion
    Last Post: 03-30-2014, 07:45 PM
  3. Check Subprogram Exists
    By guypb in forum Fanuc
    Last Post: 02-22-2008, 08:42 AM
  4. Check Program Exists
    By guypb in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 02-20-2008, 09:24 PM
  5. Hello there, glad to see a place like this exists.
    By SagaciousKJB in forum Community Club House
    Last Post: 10-15-2005, 12:46 PM
