586,106 active members*
3,109 visitors online*
IndustryArena Forum > Laser Engraving and Cutting Machines > Laser Engraving / Cutting Machine General Topics > Where can I find an affordable big laser cutter? And what power is recommended for...
Results 1 to 7 of 7
    Aug 2014
    24
    Question Where can I find an affordable big laser cutter? And what power is recommended for...
    Hello there guys, how are you? I am looking for advice please.
    I have been laser cutting (not engraving) for about 4 years now. I have 3 machines.
    1st: 40w Shenhui K40
    This is a toy, but is what I started with, and got me into lasers, and I thank it for changing my life... Laser power was very weak, cutting speed was bad, and accuracy was terrible when cutting fast. but I still love it, even though I don't use it.
    2nd: 50w Shenhui D350 500mm x 300mm
    This is my hero. Changed my life! Laser power is perfect for the stuff I cut. I cut very thin materials @ 16% power, 75 MMS. Don't need better.
    3rd: 50w Unkown Brand 700 x 500 mm. Similar to the one above, hardware and everything. I bought this one, simply because of the work space, being much bigger than the D350,thats the only reason why I bought it.
    Now, I am searching for my last laser cutter. This time, I need more power, and more space. I want to be able to cut 3/4 inch wood with it. And I don't want to do it at 10 mms ...
    Quite honestly I don't know if I can afford one... But, does any body here have an Idea where I could buy an affordable laser cutter, that would have a workspace big enough to put an entire MDF sheet from home depot in it? Or at least Half?
    What kind of price would I be looking for? I don't care where it's coming from, but I am staying away from our domestic WAY overpriced american products. Yes, the quality, looks, and perks are there but... In my opinion, if I have Enough power, Enough size, and Enough accuracy, I don't need anything too pretty.
    Thank you guys !
    Oct 2016
    14
    Re: Where can I find an affordable big laser cutter? And what power is recommended fo
    We purchased a Redsail X900 100W RECI tube (900x600mm) and it performs really well. They make bigger units including flat beds with power up to 180W. Laser Cutting Machine - Low cost Laser Cutter Manufacturer from Redsail China
    Redsail X900 900x600mm 100W
    Aug 2014
    24
    Quote Originally Posted by makercut View Post
    Thank you so much for the quick response my friend. I visited their website...
    I will definitely look into some sort of flat bed.
    What laser power would you recommend to be able to cut 3/4 inch MDF at about 20mms ?
    I want a safe power range so that I don't overwork the laser tube. So I want a little extra power, but not overkill. because i know those high wattage laser tubes are very expensive....
    Oct 2016
    14
    The 180W RECI tube should be able to cut at that speed, with a 100W RECI we can cut 3/8 inch at 20mm/s. I haven't tried cutting any 3/4 inch on our unit to check the speeds. I will give that t try in the next few days and get back to you.
    Aug 2014
    24
    Thank you so much for the help friend.
    I have a general question. What is the difference between a reci and a co2 tube?
    Aug 2016
    75
    >>What is the difference between a reci and a co2 tube<<
    RECI has had the reputation of being the best maker or CO2 laser tubes but they are premium priced. With that said, a few other tube manufacturers appear to be upping their game. Be aware that tube manufacturers have different series of tubes so not all tubes are equal in quality and warranty.
    "80 Watt” 700mm x 500mm Ke Hui 7050 Laser (Similar to the Red Sail)
    Aug 2014
    24
    Quote Originally Posted by vrc321 View Post
    Ohhh thank you for clarifying that.
    I have been using my laser cutter (shenhui d350) about 16 hours per week, for the past 3 years (16 + hours p week)...
    It still has the original tube, and is working to date .
    I use it at 16%. I do not cut wood, only mylar.
    How much time left do you think I might have on this tube?
    How do I tell when the tube is almost dead?
    I have been using Tap water, with ICE in the bucket + waterpump. is this ok?
    The fact I never use the laser at more than 16%, does this make it last longer than if I used it at 80% for example?
    Thanks so much again !!! I am just asking, because I want to make sure I have a spare tube before this one dies, and people online have said, it's bad to store a co2 tube, and not use it, i don't know if thats true or not.
  1. How do I find eye protection for my laser cutter?
    By kolleamm in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-30-2016, 09:33 PM
  2. Where can I find instructions for using MoshiDraw2015x to control my laser cutter?
    By CosmickGold in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 11-14-2015, 11:22 PM
  3. Recommended Laser Cutter
    By BryanP in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 10-16-2015, 08:46 AM
  4. 60w Chinese Laser cutter No power
    By Bpmarmstrong in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-28-2015, 01:47 AM
  5. Where to find an affordable BTR?
    By Haaatschi in forum Fanuc
    Last Post: 03-18-2006, 03:21 AM
