586,111 active members*
3,747 visitors online*
Results 1 to 6 of 6
    Jan 2007
    172
    FADAL 88HS POST VER 29
    Anybody willing to share one that they like/use? Format 2
    Dec 2011
    361
    Re: FADAL 88HS POST VER 29
    Spock,
    The OEM post processor has worked for those machines for a long time. Are you having issues using the install Format 2 post?
    Jan 2007
    172
    Sean,
    I am trying the one that came with my install Cd (29). This one would need some editing to work. This is a new-to-me control, and I was hoping to get off running parts without having to dive into every little detail that this control needs. Pull up the PP that you are sending out with 29, post some code to peck drill a few holes then get back with me......
    Dec 2011
    361
    Spock,
    From the Fadal Manual:
    N3 G83 G99 R0+.1 Z-1.2 F10. Q.1 P.02 X-.50 Y-.35
    From BobCAD:
    G83 G98 Z-.7002 R0+.1 Q.25 P.02 F.8342
    The two match exactly, just in a slightly different order, and we exclude the X and Y on the first line.
    Jan 2007
    172
    Sean,
    Maybe I have a corrupted post file? Anyway, I grabbed a Fanuc OM post from your library and had it humming in about an hour. I do not have a fresh (non-edited) copy of the Fadal format 2 post here at my shop. I do have it on my other license at home, and I will post you some code and share it with you later.
    Dec 2011
    361
    Spock,
    Here is the post I used.
    Attached Files Attached Files
  1. fadal cnc 88hs
    By nemduma in forum Fadal
    Last Post: 02-11-2015, 12:05 AM
  2. Fadal CNC 88 vs. CNC 88HS
    By jeff3 in forum Fadal
    Last Post: 01-31-2011, 02:53 PM
  3. Replies: 4
    Last Post: 04-18-2010, 05:19 PM
  4. Replies: 0
    Last Post: 03-31-2010, 03:04 PM
  5. Fadal CNC 88HS Post Processor Required
    By cncsydney in forum Uncategorised CAM Discussion
    Last Post: 12-04-2006, 07:07 PM
