my vf1 has been giving me trouble all day,first the hi/lo solenoid,now
all of my solenoids.
earlier today,it would shift to low,but not back up to high,if i valved
it manually it would shift into high and run fine.i figured if i put an m42
(forced high gear) i would be okay,i'm only using low for an 8-32 tap.
but now i get a spindle orient fault,if i valve the shot pin,i get a tool
clamp fault.i'm just not fast enough to valve all those solenoids by hand.
could i have a voltage problem?or something wrong with my air?the filter/
dryer seems a little clogged,i took the bowl off and opened the air valve
but i didn't seem to get much flow,so i tied without the filter cartridge and
got plenty of whoosh like that.but i still get the same fault.the solenoid
cicuit breaker is okay,i flipped off and on and could hear a change in the
air hissing up top.
