I am having trouble setting up my horizontal rotary table, its 24inch diameter and weighs about 20 lbs that I connected my 850 peek oz-in servo directly to. The problem is when I power on, the table keeps oscillating back and forth about 30 degrees. If I try to rotate the table using mach, it will fault the gecko 320. I have all the wiring correct, the other two motors for the other axis work great. Could the encoder be bad? Its an E5S from us digital, I'm pretty stumped on this one. Thanks
