Hello,
My name's Martin, I'm new here.
I am new to CNC machining. I've been gradually learning to use a custom built CNC router for the past few months. The machine is pretty low-end. I am now struggling to adjust its gantry, because of non-paralelism.
Anyways, I now realised that I would need an indexable/face end mill.
The chinese spindle on the machine is 2.2kw with an ER20 collet. The largest chuck is for a 13mm shank tool.
I am still working only with MDF and Plywood, and for these materials I have a 16mm(8mm shank) 2 blade end mill, that does a pretty good work a quickly clearing large portions of material.
However, my goal is to machine aluminum (aluminum castings mostly). And I will need a large tool that can quickly face my parts.
Looking in aliexpress, I see that mose indexable mills use the same diameter for the cutting head and the shank.
So the only option (without altering) is a 13mm, single blade cutter. This one:
https://www.aliexpress.com/item/13-1...0-e1a3eb3a1c77
However I'be been thinking about some of the larger tools (20 or 30mm) like this one:
https://www.aliexpress.com/item/BAP3...0-161c5041bea9
And turning on a lathe to make the shank shorter, and reduce it to 13mm.
My question is, if this is a viable option, will the spindle be able to handle such a large tool etc.?
I've red a similar thread, where one guy was asking for the same but on an ER11 1.5kW spindle, and he was told to not go for a tool bigger than 1 inch. If I follow this logic, my 2.2kW spindle should easily handle a 20mm tool.
My Feeds and speeds calculator tells me that I should run such a tool at ~4700 rpm for a 1 or 2mm deep cut, which is within the limits of the spindle (3000 - 21800 rpm). It also tells me to use TiN/TiAlN coated inserts, however I can't seem to find those. Will standard carbide coated inserts do the job too?
