586,119 active members*
3,525 visitors online*
Results 1 to 13 of 13
    Oct 2011
    13
    Pcnc 1100H model mill
    I just changed the motor to a 3hp and belt sheave to have speeds and torque from 50 rpm to 5000 rpm. Though the testing last evening to able to drill a 1.125 with a drill bit( 7/16 pilot hole) though 0.250 304 stainless plate with no hesitation or stalling of machine. Video and load meter stayed in the middle to lower part of load meter. Machine now has no hesitations when drilling 0.500 holes in stainless plate ( drilled a lot plates last night) May make kits avail if any interest out there.
    May 2010
    327
    Re: Pcnc 1100H model mill
    Pics of motor - or part number for reference? Same VFD?
    WW
    Manufacturing & Development
    ThermaeCooling.com
    Mar 2016
    23
    I would love something like this for the 440, but obviously less HP. It would be great to be able to take 0.75HP cuts at any RPM, and not struggle with drilling, and no belt changes. Basically make cuts limited by the machines rigidity, rather than the motor stalling, at any RPM.
    Dec 2009
    458
    I'm happy to hear you were able to do this motor swap. I often wondered if such a thing could be done without throwing off the motor-to-software calibrations. I have a 770 mill so in my mind I wondered about possibly being able to change out my 770's motor with an 1100's motor. If so, it might mean that a Tormach 440 owner might be able to replace their motor with one out of a 770 mill.
    Does that make any sense? I too would love to have a bit more torque to work with.
    MetalShavings
    Mar 2012
    102
    I'd be in! Let me know!
    Nov 2005
    218
    Quote Originally Posted by menzzer37 View Post
    following.
    673
    So, this is a single pulley setup then? I assume you have to change out to a matching VFD... Pics or it didn't happen
    Mar 2013
    131
    Please post more.
    Aug 2003
    329
    I used one of these on my Grizzly G0704. It is 1.5 HP. It might just fit in a 440? It is smaller than most conventional 1.5HP motors. https://www.zoro.com/leeson-metric-m...2/?q=192067.30
    Bill
    Joescnc 4x4 R&P Router, Minimill, Minilathe, CNC Foamcutter, laser cutter, Vectric Aspire. http://makermasters.com, http://themakersguide.com
    Oct 2011
    13
    Here is a video i just took of it drilling holes with no pilot hole in stainless steel 304 brushed tubing with a 1.125 KBC TOOLS Drill bit.https://youtu.be/aJrvPoA0dVo
    Jun 2012
    311
    This is great. Now show us what can it do in aluminum at 5000rpm with a shear hog or other insert EM?
    Feb 2017
    10
    Quote Originally Posted by bigbrent View Post
    Could you tell us a bit about the motor and how the install went?
    I'm interested!
    Joe
    Dec 2011
    21
    Quote Originally Posted by IMT View Post
    I couldn't agree any more...very exciting. I also would love to see it rip into and eat some 6061...but first....
    PICK UP YOUR D@MN TOOLS, SON!!!!!!
  1. Replies: 18
    Last Post: 09-23-2015, 06:49 AM
  2. Tormach PCNC 1100 4 Axis CNC Mill
    By harry8 in forum For Sale Only
    Last Post: 05-18-2015, 08:01 AM
  3. Can you really engrave with the PCNC 770 mill?
    By Smokey911 in forum Tormach Personal CNC Mill
    Last Post: 09-22-2011, 07:49 AM
  4. Will the cold from being in a garage effect the pcnc 770 mill?
    Last Post: 09-22-2011, 01:40 AM
  5. Can you External Thread Mill with a Tormach PCNC 770
    Last Post: 09-20-2011, 05:49 PM
