HTML Code:
1. what kind of Stepper Driver,and electronics do need for this design?
Drivers depend on the steppers you are using, you can purchase a kit containing most or all of what you need, like this http://www.xylotex.com/3AxSysKit.htm or this http://www.hobbycnc.com/hcncpropkg.php
HTML Code:
2. what controls tr he 3 axis, one unit or 3 controllers?
From what i've seen, it can be either, but most seem to go for one like the one's listed above.
HTML Code:
3. what sotware do u use to controll it?
You can use TurboCNC "Dos based", or Mach 2/3 "Windows based", I'm sure they might be a couple or so more, but these are the most popular, most cater towards Mach 3.
HTML Code:
4. does someone hve a detail electrical schematic for the above, how the Emergance stop wired in, are the limit stops?for the unit?
Well sorry I can't help you there, but if you keep looking around the zone, good chance you might find, or someone can answer that for you.
Good luck
Jordan.
