586,690 active members*
2,974 visitors online*
IndustryArena Forum > MetalWorking Machines > Bridgeport Machines > Bridgeport / Hardinge Mills > Putting machine on a very irregular floor that is not flat
    Nov 2011
    13
    Hi I am moving my Bridgeport miller (regular variable speed miller 10x50 table) and Bridgeport/Romi lathe. The floor is very irregular and not flat. Any advise on putting the miller on a floor like this? I don't want it to rock back and forth it should obviously be stable. I don't mind raising it a couple inches on some kind of riser if that would help. Any input appreciated, I included pictures, thanks
    Dec 2013
    5717
    Re: Putting machine on a very irregular floor that is not flat
    15362
    Quote Originally Posted by Helix22 View Post
    The normal way to do this, would be to shim the machine level in the X and Y axes, then grout it in, with cement or a mortar type mix like below
    Mactec54
    Nov 2011
    13
    Wow machine grout! I have some masonry experience so it should be super easy, I am gonna do it. Thanks I would have never thought of that.
  1. Irregular rotatory chine machine
    By JS1025 in forum USA Club House
    Last Post: 12-02-2016, 06:30 AM
  2. Putting CNC controls on an older machine?
    By Stampede in forum CNC Wood Router Project Log
    Last Post: 04-25-2008, 07:39 PM
  3. Putting a flat on drill rod
    By Fred Ming in forum MetalWork Discussion
    Last Post: 12-07-2006, 04:54 AM
