587,030 active members*
3,890 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Home made CNC mill (and some products made by it)
Page 1 of 2 12
Results 1 to 20 of 24
    Feb 2004
    77
    I have almost finished building my home made cnc. And tonight I tested it with a pen. The test was successful. I want to share first photographs with forum members.
    This is my first CNC application and I am waiting suggestions.
    You can see some other images of this tool at my homepage http://gunol.otocamlibel.com
    430
    I like the design concept.
    The first two things that spring to mind are
    #1 You are using chipboard which has very poor structural properties. As a test of concept it is fine, but re-make the machine from MDF.
    #2 the spine is just one sheet with nothing to stop it from bending. You need to have pieces at right angles running all the way from bottom to top to prevent flex here.
    Change those two things and you are off to the races!
    co
    Jan 2004
    490
    Pretty freakin cool man! Are those drawer slides? How thick is that OSB?
    Stop talking about it and do it already!!!!!
    430
    I visited your homepage. Very nice photo's!
    I could not find pictures of the machine though.
    co
    Apr 2003
    1873
    I LIKE IT! gcamlibel very nice work.
    May be some glued (glue doesn't do much on OSB but it won't hurt) and screwed wood corner braces on the boxed portion of the head.
    Keep up the great work and keep us up to date on your progress.
    Ken
    Feb 2004
    77
    Error at link and answers
    Sorry for the web address, machines photographs can be seen at http://gunol.otocamlibel.com/cnc
    This morning (about Turkish time zone GMT+2) I added a link from my homepage to cnc tool page
    Answers for Hobbiest:
    thicness of OSB is 18mm,
    and yes sliders are drawer sliders.
    (Thanks for all forum members for sharing their knowlage and special thanks for yukonho's support and suggestions.)
    Aug 2003
    318
    Talking
    Hey I like that. Very simple design. Constructed on the cheap. Thats a good thing. If people can make one for real cheap (atleast there first one) then maybe more people would be building these things. At those prices it could be a school project for the kids.
    Hows the accurecy of it?
    Donny
    Apr 2003
    416
    Cool!
    Whats the XYZ travel?
    I would suggest another piece of tape to hold down that workpiece.
    Bill
    Feb 2004
    77
    First of all thanks for your comments.
    I will securely connect z axis with other two axises. here I made just a test drive with this tool. Therefore I cannot say anything about its accuracy before finishing the tool.
    Today I will add a base in order to connect z axis with others. and I will put a dremel tool instead of pen to check its cutting ability.
    After this modifications I will post new pictures and accuracy info about my tool.
    There is a test output of my pen router attached
    there is a ink spot at left side, it is just becouse I paused the operation when pen is there in order to take a picture...
    Gunol Camlibel
    [email protected]
    http://www.rc-tuning.com
    Feb 2004
    77
    and here the answer of Bill:
    x movement is -20cm to +20cm total: 40cm
    y movement is -20cm to +13cm total: 33cm
    z movement is 0 to 13cm total:13cm (but can easly increasable)
    Thank you for "another piece of tape" suggestion
    Gunol Camlibel
    [email protected]
    Apr 2003
    292
    Looking pretty good. It doesn't appear to have much backlash. I look forward to seeing pictures of it finished with the dremel on it. Keep up the good work!
    My name is Electric Nachos. Sorry to impose, but I am the ocean.
    http://www.bryanpryor.com
    Jun 2003
    195
    Looks great!
    How much did the materials cost ?
    -Please check out my webiste-
    http://www.teilhardo.com
    May 2003
    267
    gcamlibel,
    What software/program did you use to create that "circle" drawing? I am in the process of finishing my first CNC machine and need to test it later.
    Feb 2004
    77
    I draw the circles with AutoCAD as dxf file and converted it into G-Codes with KallyCam software.
    I attached both file here. If you have any other questions, feel free to ask.
    Last minute updates of my cnc machine are posted at http://gunol.otocamlibel.com
    EDIT: Forum does not let attaching dxf files. therefore If you want it please send me an e mail please
    [email protected]
    Attached Files Attached Files
    Gunol Camlibel
    [email protected]
    Feb 2004
    77
    Cutting test is done with dremel and 3mm end mill.
    here is the result
    Gunol Camlibel
    [email protected]
    Feb 2004
    77
    and here is the final product
    Gunol Camlibel
    [email protected]
    Feb 2004
    77
    here is a new product machined with my homemade OSB mill.
    you can see more pictures about this part and my mill at my homepage.
    EDIT: This part has 50x30x18 mm outer dimensions. I wanted to write this dimensions, becouse at the picture it seems to be a big part.
    Gunol Camlibel
    [email protected]
    Mar 2004
    1147
    this is my favorite machine on this site... i love it..
    this one, and budcans..
    keep it up! but really, think about switching from particle board to MDF! MDF is much, much better... and as for making the z axis stronger - if you havent allready, you HAVE to add at least 2 1" wide ribs to the back of your machine. this small addition will make it several times stronger.
    Design & Development
    My Portfolio: www.robertguyser.com | CAD Blog I Contribute to: http://www.jeffcad.info
    Feb 2004
    77
    thanks for your support. I already added ribs to back side of z column. and I doubled the z axis OSB's with MDF.
    I am working on a router made from MDF. I use my OSB mill to prepare new routers parts. This nut holder is also a part of this router.
    here is a picture of backside of my mill
    Gunol Camlibel
    [email protected]
    Oct 2003
    927
    Yah! This machine takes the award for "down and dirty".
    ..and it has proven itself with some fine parts produced already!
    Well done!
Page 1 of 2 12
