586,076 active members*
3,779 visitors online*
    Nov 2005
    111
    Software Simodrive 611
    Hello,
    does someone knows a software to read the parameters from a simodrive 611 AM-Modul with a serial port?
    Many Thanks
    Hans
    May 2017
    Re: Software Simodrive 611
    I think you mean profibus port?
    Does it look like a serial adapter? 9-Pin D-Sub?
    Jokes on you, they only use 4 pins.
    the best way is to use what Siemens calls an MPI cable like this.
    You will need Step 7 version 5.5. To use the cable you will have to select the correct port in a little control panel section that will be installed with step 7 called "Set PG/PC Interface" to your USB port (comm1 usually) with MPI as the designator.
    You could probably hack your way through it. You can sniff the memory blocks and read /write anywhere with s7.net for c# or snap7 for python.
  1. Simodrive 611
    By eric.ciencia in forum Community Club House
    Last Post: 06-10-2013, 01:09 PM
  2. SIMODRIVE 611
    By borteh in forum Servo Drives
    Last Post: 08-08-2011, 12:22 PM
  3. Simodrive 611
    By jthornton in forum Bridgeport / Hardinge Mills
    Last Post: 06-12-2011, 08:44 PM
  4. simodrive 610
    By Roberto1759 in forum Servo Motors / Drives
    Last Post: 02-10-2010, 11:06 PM
  5. simodrive 611
    By mixalisxat in forum Servo Motors / Drives
    Last Post: 04-02-2008, 07:37 AM
