586,104 active members*
3,226 visitors online*
IndustryArena Forum > CAM Software > UG NX > Point Distribution In NX
    Oct 2016
    25
    Exclamation Point Distribution In NX
    hi guys
    i have a question about point distribution
    how can I decrease or increase the distance between two points in my extracted G-code ?
    imagine that all the operations are ready and now it's the time to get the G-code and you put the machine on linear movments , means you won't have any G2 or G3
    clearly I would end up with a G-code full of G1 movements and the only thing I want is i want this code with more lines and points . closer points
    how can I do that ?
    thank you in advance
    Aug 2008
    71
    Re: Point Distribution In NX
    I think you are asking about point density, not distribution.
    Reducing the intol and outtol tolerance values, and setting the motion output to linear, should increase the number of points.
    Mark Rief
    Siemens PLM
    Oct 2016
    25
    Quote Originally Posted by markrief View Post
    Thank you for answering
    I know where to put it on linear movement but where can I reduce the tolerance?
    Aug 2008
    71
    Quote Originally Posted by ali_mak46 View Post
    You see them in the Operation, Cutting Parameters, Stock Tab, Tolerance Group - Intol and Outtol
    If the lock is closed, you can override them in the operation, or edit them in the parent Method.
    Mark Rief
    Siemens PLM
    Oct 2016
    25
    Greattt. Thanks a million
    It was a big help coz our machine had problems with g2 and g3 and the controler wasn't meant to be for turning
    I actually I have written some parametric codes for the curve parts but we needed sth more reliable
    Thanks again
  1. Lasercut 5.3 start point and end point not matched and curve line not smooth?
    By shizyo in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 06-21-2019, 11:26 PM
  2. Looking for distribution?
    By boatmon0 in forum For Sale Only
    Last Post: 05-28-2015, 08:09 PM
  3. why the laser not line up (cutting original point does not meet end point)
    By AmyThunderlaser in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-30-2014, 03:30 AM
  4. Replies: 5
    Last Post: 09-25-2013, 05:20 PM
