hi all. i have a aluminum plate that i have to machine a form similar to a wing of an airplane. i converted the surface file from a parasolid. the ends of the "wing" are created with splines. my problem is when i machine this plate using the surface, finish, parallel, i'm getting flat surfaces instead of smooth curves. it's as if MC is creating my cutter path by using the node points of the spline and making a straight line between each point instead of following the curves generated by these points. could someone please explain what i'm doing wrong. thank you in advance.
