That all depends on the nature of your control and what type of spindle control you have.
Often with spindles that have drives for control, there are outputs like at-speed or spindle fault which the control reads and immediately does a feed hold or e-stop, depending on the designer.
With no spindle controller you would have to rely on current limiting in the drives.
Al.
Albert E.
