586,103 active members*
3,804 visitors online*
    Jan 2017
    5
    PLASMACAM SERIAL NUMBER
    I have a Plasmacam machine with me. I need to login to the Plasmacam owners community but I don't know my machine's serial number.
    Can you someone suggest me the way to find it. The machine was bought in 2008 having DHC2 controller. And FYI i have not logged in to the owners community before.
    Regards
    DAYAL DAS
    Sep 2014
    112
    Re: PLASMACAM SERIAL NUMBER
    The machine serial number would be affixed to the leg under the control box on the 'plasmacam' plaque (it should be engraved on there). If you still have any issues logging in, then give plasmacams tech support a call. They can certainly help you out way better with a situation like that.
    Best regards and good luck,
    JAG
  1. Serial number in variable?
    By ghyman in forum Haas Mills
    Last Post: 08-30-2016, 11:42 PM
  2. Help with Serial Number macro
    By NotDylan in forum G-Code Programing
    Last Post: 02-15-2015, 01:55 AM
  3. serial number macro
    By Delw in forum Haas Mills
    Last Post: 04-25-2012, 12:01 AM
  4. Lagun FTV-1 Serial Number?
    By icupeter in forum Knee Vertical Mills
    Last Post: 04-24-2011, 05:26 AM
  5. Serial number
    By fergieman in forum Haas Mills
    Last Post: 03-21-2011, 03:16 PM
