586,119 active members*
3,609 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Lessons in overkill! Welded steel, fixed gantry router
Page 2 of 3 123
Results 21 to 40 of 54
  1. #21
    Apr 2009
    290
    Re: Lessons in overkill! Welded steel, fixed gantry router
    It's more motivating when the mock-up is starting to look more and more like the final product.
    I see clearly now that the 25mm hiwin rails were not too wimpy for this machine
Name:	2017-02-05 13.43.43.jpg
    "Hey! It's that guy you are!" - Phillip J. Fry
  2. #22
    Apr 2009
    290
    Making some plywood templates for the side walls until I can get the steel ones drilled and counterbored.
  3. #23
    Apr 2009
    290
    More mock-up. Starting to look like something
Name:	2017-02-08 19.10.31.jpg
  4. #24
    Apr 2009
    290
    I spot drilled the location of the mounting holes in the steel side plates on the CNC router at work.
    I then drilled and countersunk the holes on my manual mill.
    Attachment 349654
    Test mounting
    Attachment 349656
    Another mock-up of the entire machine so far
    Attachment 349658
    I bought some 25kg bags of sandblasting sand that will be used to fill the frame when done.
    Attachment 349660
    Getting the router used to what it's going to be making
Name:	2017-02-09 21.56.26.jpg
  5. #25
    Aug 2012
    18
    Looks great! Will be following this one.
  6. #26
    Apr 2009
    290
    Starting to drill and tap the holes for the linear rails. My mill is way too small to do them all in one shot, so I am drilling 6 holes, moving the tube, indexing off the last hole and then drilling 6 more
    Attachment 350270
    Attachment 350272
    I've done a bit more work on the CAD file to visualize my goal
    I'm adding LED strips to the inside of the cover
    Attachment 350274
Name:	final router 18.jpg
  7. #27
    Apr 2009
    290
    Quote Originally Posted by papp101 View Post
  8. #28
    Feb 2017
    what controller and software are you using.
  9. #29
    Apr 2009
    290
    Quote Originally Posted by smit155 View Post
    UC300ETH controller card
    UCCNC software
  10. #30
    May 2005
    3920
    Quote Originally Posted by mcentric View Post
    Attachment 350274
    Nice! If it doesn't work out as intended you can always repurpose it as a barbecue grill!!!!
    Sorry couldn't resist the humor there. I actually like the idea of totally enclosed machinery so I'm not knocking this, I just couldn't help myself thinking about some slow cooked barbecue coming off that platform. Maybe it is time for supper.
  11. #31
    Apr 2009
    290
    Glad other people saw it too, and it wasn't just me getting hungry
    The "grate" is definitely up for design revision. Not really sure it has any significant effect either. I'll need some sort of mesh underneath the table to stop larger pieces from getting sucked into the dust extraction at the bottom.
    I'm going to make some kind of brush system to keep dust of the linear rails and ball screw, but I think I will figure out how that's gonna work when I get the machine up and running.
  12. #32
    Apr 2009
    290
    Back from winter holiday, and back to work on the project!
    The holes for the first X rail are drilled and tapped.
    Attachment 352616
    Initially I was planing on having the mounting surfaces on the steel tubes ground or milled flat to deal with the slight concave deformation. On closer inspection, the deformation is surprisingly consistent and centered on the face, and the linear rails straddle the center of the concavity, so I'm going to try them as they are.
  13. #33
    Apr 2009
    290
    hey!
    Progress has been slow, but updates here have been non-existent. So I guess it's time to catch up:
    * A quick preliminary test to see if my X and Y axis are close to being square.
    Attachment 359174 Attachment 359176
    * Using 3D printed brackets to mock up the X axis
    Attachment 359178 Attachment 359180 Attachment 359182
    * Getting the Y axis components in place
    Attachment 359184Attachment 359186Attachment 359188
    * Filling the lower frame with sand using an old oscillating sander to compact the sand. The joints are only stitch welded, so bondo was used to fill the gaps so the sand wouldn't run out.
    Attachment 359190Attachment 359192
  14. #34
    Apr 2009
    290
  15. #35
    Apr 2009
    5516
    Looking good!
  16. #36
    Apr 2009
    290
    Quote Originally Posted by louieatienza View Post
    Looking good!
  17. #37
    Apr 2009
    290
    Well, it's been a while and frankly not much has been done since last I posted. What I did realize though, was that the steppers weren't gonna cut it, but not for the reasons you'd expect.
    The speeds were as expected, but nothing more. The biggest issue were some weird resonances that I just couldn't get tuned out. I played around with micro stepping, speeds, motor mounts, damping etc but it was still there to an unacceptable extent.
    This is my first full steel frame build, so these could be common issues that are known, just not to me 😉
    Some of the upper tubes haven't been filled with sand yet because I am still taking it apart regularly, and it would just make a mess. This could obviously be some of the reason for the resonance.
    So I've decided to try to solve both the speed and noise issues by throwing some money at the project, and getting it to the stage I was eventually planing to get it to... just not this quickly 😁
    Meet the latest additions:
    Attachment 371036
    ClearPath servos from Teknic
    I'll post again once I get them installed.
    M.
  18. #38
    Mar 2014
    735
    That oughtta do it! :banana:
  19. #39
    Any updates?
    Nic
  20. #40
    Apr 2009
    290
    Quote Originally Posted by Mercuryv8 View Post
    Any updates?
    Nic
    Sorry for the really slow reply!
    Yes, the servos are in and work great. Definitely worth the investment. I had made a temporary 3D printed Z motor mount that ended up causing me a lot of grief with resonance in the servo that just couldn't be tuned out. The solution was of course as easy as just machining an aluminum mount and that has solved the issues.
    The dust shoe is loosely based on the one on the MultiCam Apex router I have at work. It's 3D printed, has a built in camera and works great!
    I'll post a video soon. Meanwhile here are some pictures I just took of it while making a test neck for a series of guitars I'm making.
Page 2 of 3 123
  1. steel/aluminium fixed gantry build
    By v2tiller in forum DIY CNC Router Table Machines
    Last Post: 06-16-2020, 09:42 AM
  2. Fixed Gantry Steel, wadeodesign
    By wado1971 in forum DIY CNC Router Table Machines
    Last Post: 01-06-2018, 02:12 PM
  3. My First All Welded Steel Router Design
    By widgitmaster in forum CNC Wood Router Project Log
    Last Post: 10-18-2008, 03:07 PM
