586,113 active members*
3,291 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > CNC Wood Router Project Log > Last One - 4'x6' Steel, Epoxy and ClearPath servo's
Page 22 of 23 1220212223
Results 421 to 440 of 452
  1. #421
    Feb 2015
    113
    Re: Last One - 4'x6' Steel, Epoxy and ClearPath servo's
    great information and ideas I found here.
    For plasma CNC ( stepper motor 1.8° with planetary gearbox 3:1 + micro stepping probably 10x) what you recommend me to use, rack and pinion module 1 or 1.5 ?! And what is the best (ideal) pinion diameter (number of teeth for the pinion ) ?!
    What is the advantage of helical rack ?!
    Appreciate your help!
    Sent from my A0001 using Tapatalk
  2. #422
    Mar 2014
    735
    Assadi - Plasma is a different machine with different requirements. Anything I could tell you would be just a guess on my part. With that said if I were building one I would use regular straight rack and not helical, or even a good belt drive system. You want speed more than rigidity (to a point). And use good shielded cable on all your wires. There's lots of electrical noise on a plasma machine.
  3. #423
    Helical is quieter, and can carry higher loads.
    Number of teeth depends on the motor and drive, gear reduction, and how fast you want to go.
  4. #424
    Dec 2017
    8
    Quote Originally Posted by 1Jumper10 View Post
    http://www.cnczone.com/forums/fineli...m-posts-6.html
    In the linked thread, post #110 shows the correct diagram. I pasted it below. Dont use the dashed line that shows a connection to X210. Use a 1-3k-ohm, 1/2watt resistor connected as shown at the VFD. According to Weerasak at CNCroom, the resistor pulls up the signal to positive value that can be read by the VFD. Its been working great for me. The Jumper wire on the VFD between terminals PLC and P24 is not used and has to be removed.
    Thanks for your help, wiring ist done!
    But now I have the next problem:
    If I start the spindle, I cannot adjust the spindle speed! The VFD receives directly the max value and goes to 400Hz!
    Any idea?
    Sent from my ZUK Z2121 using Tapatalk
  5. #425
    Mar 2014
    735
    Quote Originally Posted by DIAY View Post
    Any idea?
    I'd check your parameters in your VFD. Make sure your speed command source is set correctly. Also check your Step and direction spindle settings in UCCNC. I'm not at home at the moment so I can't refer to my settings but I'm certain I listed them here in my build log.
    Sent from my Pixel XL using Tapatalk
  6. #426
    Dec 2017
    8
    I had my VFD/spindle already running with the analog input (0-10V).
    So I changed only the parameter A001 to 6 (pulse train).
    Is that probably not enough?
  7. #427
    Dec 2017
    8
    Unhappy Re: Last One - 4'x6' Steel, Epoxy and ClearPath servo's
    Last test result from this evening - I took your settings from post #77 (except F002/3 and B090&095 because I don't have a brake resistor):
    F002 ACCELERATION TIME 10
    F003 DECELERATION TIME 10 BRAKING RESISTOR INSTALLED
    A002 RUN COMMAND SOURCE (USER PREFERENCE) 01 digital input
    A003 BASE FREQUENCY 400
    A004 MAX FREQUENCY 400
    A041 TORQUE BOOST 01 AUTOMATIC
    A044 V/F CHARACTERISTIC CURVE 03 SENSORLESS VECTOR
    A045 V/F GAIN 50
    A082 AVR VOLTAGE SELECT 02 220 V
    A097 ACCELERATION CURVE 00 LINEAR
    A098 DECELERATION CURVE 00 LINEAR
    B012 LEVEL OF ELECTRONIC THERMAL PROTECTION 50
    B021 OVERLOAD RESTRICTION OPERATION MODE 00 DISABLED
    B082 START FREQ 6
    B083 CARRIER FREQ 7.7
    B090 DYNAMIC BRAKING RATIO 10
    B095 DYNAMIC BRAKING CONTROL 02 ENABLE ALWAYS
    C028 AM TERMINAL SELECTION (USER PREFERENCE) 01 OUTPUT CURRENT
    C064 HEATSINK OVERHEAT WARNING 75
    But the problem is still the same: if I switch on (spindle button), independently from the preselected SXXXX, I see in the VFD display always only 400 Hz - also the sliders from the 2017-screen are ineffective!
    It seems that the VFD receives a wrong signal from the UCCNC/UB1 - or I'm wrong?
  8. #428
    Dec 2017
    8
    A045 V/F GAIN 50
    B082 START FREQ 6
    And this is my UCCNC setup acc. to the given infomatons (See attached photo)
  9. #429
    Dec 2017
    8
    Re: Spindle control with step - direction pulse stream
    Last couple days I have been learning the MB2. Its not as difficult as I thought and is a very good board. Its a 24vdc board which is new to me but apparently not to many others My relay board was 12vdc and this will not work. I bought this relay board/module from amazon to replace it:
    ....then I had to figure out and set the pulses per revolution and the acceleration. The Hitachi VFD's EA terminal for pulse stream input will accept a max signal frequency of 32 Khz. At 24000 spindle rpm the VFD driving frequency is 400 hz or, 400 pulses per rotation if you do the math.
    32000/400 = 80.
    I didnt need max resolution for my spindle so I started with a setting of 32 in UCCNC. The acceleration I set at 50 steps/sec squared. I hit start button and the run command activated but the spindle didn't start. For a few seconds... then it started to spin and accelerate very slowly. And it only got to 200hz before it maxed out.
    Anyway long story short, after a little experimentation, I set the steps per rotation up to 64 and the acceleration up to 10000. Then it worked great. I dont know why I had to set the acceleration so high. Anyway, its not on a machine yet but on the bench I'm pretty happy with how its working.
    Currently I'm also setting up my VFD and the UCCNC SW. You can adjust the input frquency for the Hitachi WJ200 VFD with the parameter P055 (=> 32 kHz), but where do can adjust the output frequency from the UC300ETH board (from where do you know that number)?
    I have still an off-set between the selected rpm and the real rpm at the spindle: S24000 => 19000 1/min ???
  10. #430
    Mar 2014
    735
    DIAY - The MB2 itself just relays the output frequency UCCNC sends it. The output frequency is set by the "Steps per Revolution" setting in UCCNC on the Spindle set up tab. I think the problem is a setting. Try cutting your steps per revolution in half (32) and see if then it runs at a slower speed. If it does, then its likely just a setting that needs adjusting. If there is no change, then I would check your settings and make sure that your VFD is set to accept speed control from the EA pin. I'll double check my settings but it will be later today before I can. Also, instead of using the slider to adjust spindle RPM, try directly entering a value in the MDI field or the RPM percentage field underneath the slider.
  11. #431
    If you are controlling the spindle with step/direction, wouldn't that be the steps/rev value?
    Not sure why you just don't use the UB1's 0-10V, which is very simple to setup.
  12. #432
    Mar 2014
    735
    DIAY - see post #53 in this thread: http://www.cnczone.com/forums/fineli...m-posts-3.html
  13. #433
    Dec 2017
    8
    Re: Spindle control with step - direction pulse stream - heureka!!! :)
    That made mynight!!!
    :cheers:
    Robert, thanks for clearing up!
    Martin
  14. #434
    Mar 2014
    735
    Did you get it working?
  15. #435
    Dec 2017
    8
    YES!!!
    I have a deviation now less than 1 %
  16. #436
    Mar 2014
    735
    Great!
  17. #437
    Jan 2017
    84
    Hi jumoer10
    I was reading your most interesting Build Posts, as I said before it is awsume.
    I was wondering if is it possible for you to send me the drawing or a clear pictures of your Motor and gear box mount Plates or so called motor gear box flanges? I am attaching one of your pictures
    Please send if you can the drawing of both plates the steel and aluminum plates
    regards
    jhonansaro
    Attached Thumbnails Attached Thumbnails f202bf992fa0b400f36d4fe276a7bcd1.jpg
  18. #438
    Mar 2014
    735
    Johnansaro - The dxf drawings I posted in this thread: http://www.cnczone.com/forums/usa-rf...8-autocad.html
    The units are in millimeters.
  19. #439
    Hi 1Jumper10, just thought I would comment on your incredible build and journey, it looks fantastic already and am sure i will be even better when it's finally completed. I have spent a good part of the day reading quite a bit of this thread, and have learned a few things already. Thanks for letting me look in on your work.
    I especially liked the main structure and the way you filled in the box section with "high density polyurethane foam" and also the sand. I was thinking that filling box section with something to dampen vibration may work (and be a lot cheaper) and you just confirmed that it actually might. I also enjoyed the talk about the Clearpath motors and Steppers, although I'm still learning about all that.
  20. #440
    Mar 2014
    735
    Thanks Krispee. It's working fantastic. Here's a pic of a project I'm working on. In the pic it had been running for 2 hrs with about another hour to go with no issues. The software I used to generate the toolpaths is inefficient as the file is gigantic but there is a lot of detail in it.
  1. HELP!!! Wiring a Clearpath servo to a C32S - DUAL PORT MULTIFUNCTION BOARD
    By 09milam in forum SmoothStepper Motion Control
    Last Post: 01-26-2017, 03:11 AM
  2. Replies: 5
    Last Post: 09-15-2016, 05:57 AM
  3. Epoxy granite filled rails - how big to mill steel?
    By cnccnc222 in forum Epoxy Granite
    Last Post: 05-12-2014, 02:45 PM
  4. Epoxy joints for steel frame
    By thunderdork in forum DIY CNC Router Table Machines
    Last Post: 10-13-2012, 05:03 PM
