He's looking into it, but I can't say for sure until it's ready. I would expect it to take at few months.hi gerry it is true that cncroom will build breakout board for uc300eth?
Not sure what you mean? I plugged it in the easiest way, where all the plugs line up.and why you don't the 1st and the 2nd port of mb2 to the 2nd and the 3rd of uc300eth?
MB2 Port 1 to UC300eth Port 2
MB2 Port 2 to UC300eth Port 1 (Pins 2-9 are input pins.)
MB2 Port 3 to UC300eth Port 3
Port 1 and 3 on the MB2 must go to ports 2 and 3 on the UC300eth, in either order.
Port 2 on the MB2 can go to ports 1,4, or 5 on the UC300eth.
Both the UC300eth and the MB2 have +5V on pin 26. To prevent damage to either one, I'm not using pin 26. I used 25 wire ribbon cables for my custom cables, and I cut wire 26 on the test cables I used at first.
