586,113 active members*
3,515 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Just a stupid question
Results 1 to 8 of 8
    Feb 2017
    32
    How come Okuma has to be so different? I'm talking about the control and its use of G codes etc. And how many have retrofitted a Fanuc control on them?
    2932
    Re: Just a stupid question
    I started out on Yasnac's and Fanuc's, and I hated every time I had to work on an Okuma control. However, most of the folks I know that started out on Okuma controls HATE when they have to work on a Fanuc or other non-Okuma.
    I guess it's all relative.
    Feb 2017
    32
    Yeah what you get used to. But the problem is pretty much everything is Fanuc like as far as G codes etc. If I remember Okuma does some weird thing with G90 that would really mess me up if I had to deal with manually programming it. Also I can imagine that things like macros are a mess as well.
    Jun 2015
    4154
    hy there is a fashion to take G codes from the user interface, thus leaving them to the software : igf / cam, etc
    in this way, users / programmers may focus on things at a macro level, while the software will generate code at micro level
    so this fashion tends to make the programmer work easier
    is good to know bought micro and macro levels, so to say when you mastered them, you may program any cnc, without thinking that is Okuma or whatever else
    Okuma has some particularities, and the control is one of them
    once you will find your inner peace with the G codes, you may start discovering what makes Okuma to be Okuma
    Apr 2009
    1262
    Once you get used to the Okuma you will wonder why the Fanuc is so "different". Why EOB insert? Why do I have alter insert etc. in the editor? Why can't I upload download while running? Why aren't graphics available showing what's running? Why do I need to zero return? Why can't I check panel switches? Why can't I use more than 3 m codes max?
    It's all what you are used to. Everyone has different g and m codes.
    More Fanuc guys love their Okumas than Okuma guys like their Fanucs from what I've seen.
    Don't downgrade the control. ;-) Its not worth it.
    Best regards,
    Experience is what you get just after you needed it.
    Feb 2009
    6028
    Geez wiz, no modern fanucs? Yes okuma was light years ahead in the 80s and 90s, now its all pretty much same same. I will say fanuc is way better at being able to get old parts, and cheaper than okuma. Anyone needing a VAC type A or a BLD drive will hate okuma!
    Sent from my SM-T813 using Tapatalk
    Jun 2015
    4154
    hy mr Wizard i did not understand some of your statements :
    Why EOB insert? + Why do I have alter insert etc. in the editor? > i google it, and i think that these are "veteran edit functions", that maybe now are default on osp300
    Why can't I upload download while running? > i think this is something about data pumping into the cnc ? like to reload faster a file after it had been edited ? i have no clue
    Why aren't graphics available showing what's running? > i don't use graphics ; also i think that graphics and CAS leads to overload computer from osp300 lags from time to time, so is better to "pet" him
    Why do I need to zero return? > this is because of the absolute encoders i understood this later ... better than never
    Why can't I check panel switches? > you shared, more than once, procedures about these; still out of my experience
    Why can't I use more than 3 m codes max? > i think that this extra M codes, is about macros or maybe controlling something outside the machine, like a feeder / robot; etc
    however, this thread remind me that i wish to create one about Okuma's particularities, but 1st i need to read some more
    Jun 2015
    4154
    Quote Originally Posted by underthetire View Post
    i am not into this for as long as others, but i guess this is true : differences will decrease in time; mainly because of globalization
    this is obvious in automobile market : all new common models look prety much the same : same recycled design same provider / tehcnology for steering wheel, senzors, lights, etc
  1. may be a stupid question but......
    By kaighn80 in forum Welding Brazing Soldering Sealing
    Last Post: 03-30-2012, 02:59 AM
  2. Maybe a stupid question
    By haroldj in forum Stepper Motors / Drives
    Last Post: 04-24-2008, 07:17 PM
  3. probably a stupid question
    By mad.sculpture in forum Linear and Rotary Motion
    Last Post: 10-09-2007, 10:55 PM
  4. Another stupid question?
    By t305100 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 09-04-2006, 02:01 AM
  5. Stupid Question
    By CNCRob in forum Community Club House
    Last Post: 09-04-2005, 07:42 PM
