586,116 active members*
3,531 visitors online*
IndustryArena Forum > CAM Software > Autodesk CAM > Any way to get simulation to actually simulate your machine's acceleration?
    Jan 2013
    263
    I know what my machine's accel values are, and if Fusion 360 did, it might actually be able to give me some accurate simulation times. With a lot of tight corners, I end up with 2x or more actual machining time than their best case scenario estimates. It's hard to compare which toolpaths are best if I don't know the actual times for them.
    Mar 2014
    44
    Re: Any way to get simulation to actually simulate your machine's acceleration?
    You can write a postprocessor to incorporate these times. Take the setup-sheet as a basis. It will take you some time though...
    Aug 2012
    181
    Quote Originally Posted by Arjand View Post
    the post processor is involved in the simulation in Fusion360?
    Mar 2014
    44
    Quote Originally Posted by MarcusWolschon View Post
    No, but you can influence the cycle time calculation on the setup sheet
    Verstuurd vanaf mijn SM-G955F met Tapatalk
    Aug 2012
    181
    Okay.
    Thanks.
  1. Replies: 4
    Last Post: 09-22-2016, 11:31 AM
  2. Acceleration Plasma cutting machine.
    By dck in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 03-07-2016, 02:32 PM
  3. Machine simulation
    By zarif in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 10-31-2013, 05:02 PM
  4. Machine Simulation
    By Sidni in forum GibbsCAM
    Last Post: 01-08-2012, 01:54 PM
  5. Replies: 0
    Last Post: 07-31-2008, 10:35 AM
