586,082 active members*
3,613 visitors online*
    Jan 2009
    39
    DNC trouble Meldas
    Hello everyone.
    I need help whit my PC to CNC connection. The machine is a Chen-Ho with a Mitsubishi Meldas 520 controller.
    Everything has worked fine with sending programs to the machine for a few years.
    Machine have 25pin connection, computer USB. I used 25pin to 9pin cable (2,5m) to usb-adapter to active usb-cable (20m). This worked for a year. Before that i used another computer whitch had a 9pin connection.
    Anyhow, suddently it stopped working, the computer alarmed that the USB-port demanded to much power and the adapter was i little bit warm. I changed the USB-adapter and USB-cable and it worked again. After maybe two hours it was the same again. Only this time no alarm on the computer and no heat, just no connection. The DNC-program could not find the COM-port for the cable. At this point I replaced the power-supply in the PC, just to try something.
    Then I ordered a new 20m 25pin to 9pin cable and a new USB-adapter. This worked for a little more than a day, it stopped in the middle of drip-feeding. Now the alarm physical error E08 occurs in the machine so it appears as if there is some sort of connection. Also the DNC-program can still find the COM-port. All the parameters are the same as before in both computer and machine.
    I tried whit my old 25pin to 9pin cable and a new USB-adapter but it doesnt work either.
    I have checked the cable in the cabinet of the machine and all wiring looks fine.
    I dont know what to do next.
    Very greatful for any help!
    /Samuel Olsson, Sweden
    2932
    Re: DNC trouble Meldas
    Is your PC a notebook, or desktop/tower? If it's a tower, you might look at doing away with the USB-Serial converter and invest in one of these:
    PCI - Serial - Serial/Parallel - IT PRODUCTS
    Jan 2009
    39
    The PC is a desktop.
    I will check this out.
    Thanks.
    Jan 2009
    39
    This problem is solved, turned out to be a broken fan in the electric cabinet. Replaced the fan and the problem has not happened since.
  1. Trouble cutting circles. Trouble with y-axis
    By chrisv7 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 06-08-2016, 09:43 PM
  2. Spindle trouble Meldas 320m PCV-50
    By Monster_Shop in forum OKK
    Last Post: 07-11-2015, 12:05 AM
  3. Meldas 60
    By agu in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 09-18-2012, 11:13 PM
  4. OKK MHA 300 II WITH MELDAS 86B
    By BKCOM in forum OKK
    Last Post: 09-08-2011, 04:18 PM
  5. meldas YM 2B
    By cadcamsolutions in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 08-04-2009, 02:06 AM
