586,112 active members*
3,128 visitors online*
    Jan 2007
    35
    Red face Parametric Programming
    Ive heard a little about parametric programming (MACRO B). I know nothing about it. What Ive read sounds great - I need to learn more...but can't find much literature about it particularly literature which is available in South Africa. Any one know how I get get hold of some???
    Check out...
    Check out Dolphin CAD/CAM.
    www.cadcamconsultants.net
    Nov 2005
    1468
    Eh? I use Dolphin CAD/ CAM and I haven't heard of parametric programming either... is it a name for something I already do. but call something else or am I just thick?
    I love deadlines- I like the whooshing sound they make as they fly by.
    May 2006
    214
    I go something for you -
    And you are right.This is great stuff, I am a beginner myself. I started a couple a weeks a go.
    Good Luck
    George
    Attached Files Attached Files
    24221
    Quote Originally Posted by ImanCarrot View Post
    This is usually an option on many machines, its a way of enhancing the G code programming to include mathematical and logic routines to be written, it uses variable storage registers for values to act on etc, also machine function registers can be read that will monitor the state of the machine, like servo position etc for writing probe routines as an example.
    Al.
    Albert E.
  1. help with parametric programming on 840c
    By craigh10 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 11-10-2009, 08:35 AM
  2. parametric programs
    By DaveN in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 11-22-2007, 01:55 PM
  3. Parametric Programming
    By widgitmaster in forum BobCad-Cam
    Last Post: 05-04-2006, 07:04 PM
  4. parametric programming
    By Karl_T in forum CamSoft Products
    Last Post: 05-24-2005, 08:58 PM
  5. Macro/Parametric Programming
    By screensnot in forum Fadal
    Last Post: 03-29-2005, 03:45 AM
