Hi, anyone knows what post processor to choose from Aspire to create .nc files for 1325 Omni CNC Router??
Thank you.
Thank you.
Which controller, that's more important.
Sent from my LG-D852 using Tapatalk
In case anyone is wondering, I'm the twin of the other gfacer on cnczone...
Hi thanks for your reply.
I am very new to cnc so i am not sure how to get the controller specificaction.
Please find attached the description of the machine, maybe it helps:
1 OMNI 1325 Basic CNC Router with 6.0kw HSD spindle
X,Y,Z working area: 1300*2500*200mm
Drive and motor: Yako drive and stepper motor
Table size: 1500*3040mm
Spindle: 6.0kw, Italy HSD aircooling spindle, 0-18000RPM
Inverter: Fuling frequency inverter
Spindle Protection Device: Selfcooling for aircooling spindle
3.0kw Dust collector with 2 cloth bags and Dust hood
Bakelite table combined Aluminum T -slot extrusion,vacuum table
Mist Oil Sprayer for Aluminum
X, Y, Z Travelling Potioning Accuracy: ±0.05mm / 300mm
X, Y, Z Travelling Repositioning Accuracy: ±0.05mm
Frame: Big thickened Steel Square Tubes, thickness up to 8mm
X, Y structure: Helical Rack and pinion drive, Hiwin square rail linear bearing 20mm
Z axis structure: Taiwan TBI ballscrew and Hiwin square linear rail 20mm
Max Rapid Travel Rate: 32,000mm/min
Max working speed: 20,000mm/min
Working voltage: 220V, 50Hz
Command languages: G code
Control system: DSP remote controller
Software: Ucancam V10 English version
Limit stop: Extra-travel limit stop and hard limit stop
Emergency stop and Switch: Japan Omron emergency stop and SCHNEIDER switch
Package: In wooden box : 3200*2100*1900mm(12.77CBM)
Gross weight: 1950KGS
So you have a dsp controller, and you'll need a dsp post. Look for Rusty in the omni sub forum and send him a pm or email me if he doesn't respond. He's got a dsp controller and I have his email if he doesn't respond on cnc zone.
Does anyone know what post processor I need for Omn-1325 cnc, I am using Artcam Pro
Does anyone know what to use for the Omni-1325 using artcam?
NC studio ATC
test it
Amazing! Your substance is exceptionally helpful for us to give such a decent article.
https://software.informer.com/forum/user/104523/about/
https://www.stripperweb.com/forum/me...?540273-akriti
https://cdr.cz/profil/9c6fhcsxzq
https://www.pokecardex.com/forums/me...ofile&u=429067
https://plantvillage.psu.edu/users/69191-akriti-verma
https://studiumfc.umontreal.ca/user/....php?id=346258
https://forum.instaforex.com/index.php?showuser=51287
Great! Thanks for sharing it's a valuable info
